Old 13th August 2007, 12:22 AM   (permalink)
Talking Homemade Helping Hands!
This is an easy way to make yourself your own pair of helping hands. Helping hands (or 3rd hand) is a simple mechanism that holds the part(s) that you are soldering together, aka a PCB Board, wires, etc. Very handy (ha ha) and you will love yourself for making one! Mine cost only $2!
Parts needed:
10-12 Gauge Wire (1ft or more)
2 Alligator Clips (ones that fit 10-12 gauge wire)
Small block of wood capable of weighing down the helping hands
Tools needed:
10-12 Gauge Wirestrippers
Staple gun
Large Pliers
Step 1: Strip about 1/2 inch (1.5cm) off each end of the wire.
Step 2. Staple the middle of the Wire to the Block of wood or your weight. Make sure you put a bunch in there to hold it down well.
Step 3: Put the alligator clips on each end.
Step 4: Clamp the alligator clips very hard on the wire, so it holds down well.
This is a cheap way of making very effective helping hands. You could put anything you want on the end of the wires, and even add more arms if you want to (I made myself the octupus, a 8 legged helping hands). Be careful!
Krumlink is offline
Old 13th August 2007, 03:45 AM   (permalink)
Another way that you can do it is to cut the wire into 2 seprate peices, and put each end on a round hole socket, like for bolts in the center. You then bolt that onto your wood thing or whatever. That also works well. I am going to build another helping hands thing, except with 22 gauge wire and build a ton of hands for it (a new octupus). Let me know how your coming along on it, and if its working out for you.
Krumlink is offline
Old 13th August 2007, 04:40 AM   (permalink)
Can you post some pictures? I face some problem when doing soldering sometimes
Superman returns..
bananasiong is offline
Old 13th August 2007, 05:41 AM   (permalink)
Sure here are some pictures!
You dont need to solder anything; just a good strong pair of pliers to crimp them on to the wire.
Help 1 shows a general overview of the Helping hands. I mounted it to PVC board instead of wood, because I couldnt find a peice.
Help 2 shows a closeup of one claw.
Just crimp it on there.
Krumlink is offline
Old 14th August 2007, 06:53 AM   (permalink)
anybody try building it? I made a amputated octupus (4legs) with the bolt instead. Use a bolt, works better.
Krumlink is offline
Old 15th August 2007, 07:13 AM   (permalink)
Just wonder is the stapler bullet strong enough to hold the wire?
Superman returns..
Old 15th August 2007, 01:46 PM   (permalink)
I worry that the wire will snap after a few uses. Nice idea though.
yngndrw is offline
Old 16th August 2007, 04:09 PM   (permalink)
Talking
very bright idea..
hamm3rst0rm is offline
Old 16th August 2007, 04:15 PM   (permalink)
The wire of the holding hands breaking? It wont snap if its really thick, or really thin.
Krumlink is offline
Old 16th August 2007, 07:17 PM   (permalink)
How brittle the wire is does not depend on how thick it is.
yngndrw is offline
Old 16th August 2007, 08:13 PM   (permalink)
Even if it snaps, big deal wire is so cheap it doesn't matter.
Screen name: Aloone_Jonez
Hero999 is offline
Old 16th August 2007, 08:25 PM   (permalink)
Is it worth having to re-build it every few uses in order to save a couple of quid ?
I'm sure there are better things to use than wire which would still be cheaper though. Any ideas ?
yngndrw is offline
Old 16th August 2007, 09:18 PM   (permalink)
How many uses do you get though?
Take a piece of wire that thick and see how many times you can bend it before it snaps.
By the way it's better to use thinner wire as you can get away with as you can bend it more times before it snaps.
Hero999 is offline
Old 16th August 2007, 10:19 PM   (permalink)
Ive been constantly using mine now for about 2 weeks, and every wire has the same strength as it had when i first made it.
Krumlink is offline
Old 16th August 2007, 11:12 PM   (permalink)
Fair enough, I'm just used to solid core cable breaking constantly. :c Maybe it's the heat from soldering ?
yngndrw is offline
Simple Hands free car phone yagtoby Electronic Projects Design/Ideas/Reviews 1 29th November 2006 07:48 PM
Homemade LC meter alisarhangpour General Electronics Chat 10 4th January 2006 05:43 PM
Anybody interested in helping start a new project website? ukeee General Electronics Chat 15 26th January 2004 11:35 PM
telephone hands Free circuit tsa3d Electronic Projects Design/Ideas/Reviews 3 27th July 2003 03:46 PM
Nokia hands free connetion tsa3d General Electronics Chat 0 19th May 2003 01:50 PM
