__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | ||
| Maybe stripping with side cutters isn't the best idea after all. :c I'll have a look around for some decent strippers. | |
How much trouble would it be to bend a wire a few times? I think your design is fine, no mater what type of wire you use. Copper tends to work-harden if bent in the same place, maybe iron wire for high usage. but the likelihood of that happening in your design is nil. Testing; I took a piece of solid hook-up wire (22 gauge) and bent it back an forth, over 30 times, in a 180° arc while holding it in a pair of round nose pliers! Made the same test with a 24 gauge wire and it broke (didn't hear any snap) after only about 20 bends. So much for all the theory. Your design it wont be put to this kind of bending so it should last forever. For a little fancier design, I might look at a small table top tripod (less than $5) that has some kind of spiral legs, only 3/16" dia. (don't know what it is called), they would make great arms. Keep up the good works! Rolf | ||
| You could easilly reverse the effects of wear by heating the wire untill it's cherry red but that will probably distroy the chrome plating on the crocadile clips.
These numbers are for pure copper and might be slightly different for copper wire. | ||
| Work hardening should not be a big deal. If one section of the wire gets hard it will just bend in a softer area. The wire should last long enough to be pratical. The wires can always be replaced.. Take a 4 or 5 inch bit of wire and hold it by the ends when you bend it. It is difficult to break because it does not always bend in the same place.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
Would 950°F (510°C in English) be hot enough to destroy chrome plating?
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
| Simple Hands free car phone | yagtoby | Electronic Projects Design/Ideas/Reviews | 1 | 29th November 2006 07:48 PM |
| Homemade LC meter | alisarhangpour | General Electronics Chat | 10 | 4th January 2006 05:43 PM |
| Anybody interested in helping start a new project website? | ukeee | General Electronics Chat | 15 | 26th January 2004 11:35 PM |
| telephone hands Free circuit | tsa3d | Electronic Projects Design/Ideas/Reviews | 3 | 27th July 2003 03:46 PM |
| Nokia hands free connetion | tsa3d | General Electronics Chat | 0 | 19th May 2003 01:50 PM |
