Old 12th August 2007, 03:53 AM   (permalink)
Default LCD with Center Damage
I have a 3.5" x 5.0" LCD on my GPS. There is a circle of about 2.0" diameter in the center of the display that is blank, no data displays. Everything outside this circle appears normal.
What caused a blank circle like this and can it be repaired in any way.
Thank You
KS2K
ks2k is offline
Old 12th August 2007, 08:47 PM   (permalink)
Probably a crack in the display, no it's not repairable, you'd have to replace the entire display.
straight answer, har har."
Sceadwian is offline
Old 12th August 2007, 09:21 PM   (permalink)
Ok, Thank You.
One more question since this display is not repairable. I have a spare unit that has a display that is weak. The Numbers/letters are weak with little contrast. Is this a display or display driver problem. If a driver problem, then I could swap the actual LDC.
Thank You
KS2K
ks2k is offline
Old 12th August 2007, 09:38 PM   (permalink)
Have you looked at the software settings?
The chances are all you need to do is tweak a setting to adjust the contrast.
Screen name: Aloone_Jonez
Hero999 is offline
Old 12th August 2007, 10:19 PM   (permalink)
I does respond to the software brighteness and contrast, but now where near enough to amke it a good display. Thats why I wonder about a driver component failure ?
KS2K
ks2k is offline
Old 12th August 2007, 11:11 PM   (permalink)
Sounds like a real quality product =)
Most (any that I've heard of) LCD failure modes simply result in the display ceasing to function. Then again it depends on of the LCD is a module or just a simple display. If it's a module the driver is on the board with the LCD which means putting it in the non-functioning LCD's unit will result in the same dim display. If it's truly just an LCD unit with connections to a driver board inside the unit then swapping out the display may work, unless it's really a faulty display driver problem in which case you're pretty much out of luck. If it's not too difficult try swapping them.
Old 12th August 2007, 11:42 PM   (permalink)
Ok, will do. Thanks for your help. Easy to swap LCD's
KS2k
ks2k is offline
Lcd savnik Micro Controllers 9 25th July 2007 04:59 PM
problem with LCD meera83 Micro Controllers 9 17th July 2007 03:20 PM
Help understanding the Unicorn Kyle-s4h Micro Controllers 2 5th June 2007 07:09 PM
PIC16+Parallel lcd - by twitchy Nigel Goodwin Micro Controllers 16 18th May 2007 11:44 AM
89c4051 4-bit controlled LCD sporadic screwup Pax Writer Micro Controllers 7 26th April 2007 06:58 AM
