| hey, Im just wondering about hvdc, how do a get a dc stream of current in a hv, the cloestest thing i can find is all thoes 555 driver circuits, but this creates pulses, I want to build a lifter, I have lots of hv devices, but they are all ac , is there even such thing as dchv, or do I stick with the hf pulses? also im wondering if maybe a ac current would work a lifter, what if I put in a hv capactior, would that rectify my ac signal, I have no hv diodes, is there a cheap method??? | |
| You haven't provided enough information. What voltage at what power level?
| Hi doggy, It has to be DC for a lifter. The lifters don't have much lifting power, the DC supply is usually fed to the lifter from trailing wires, thin ones, from the supply on the ground. The voltages have to be in the thousands. The current is insignificant. They are interesting, but somewhat disapointing projects. They barely float, and are practically uncontrollable. You are not going to find chips for this sort of thing. These things are quite dangerous, and from your apparent inexperience i would discourage you from making any high voltage equipment unless you are being supervised by somebody more familiar with this sort of thing. Regards, John
__________________ ************************************************** ***************** | |
| AC and DC are basically the same thing. If you want to smooth AC into a more DC like signal simple add a properly valued capacitor.
| "AC and DC are basically the same thing. If you want to smooth AC into a more DC like signal simple add a properly valued capacitor." You learn something here every day. John
| just get a flyback out of a old monitor, they have internal rectification, and an output current of1-2ma at about 20kv. those values work for a largish lifter, as i have tried it
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
| ya, im actually useing this application for a diffrent hv expirment, that requires similar specs, and yes a capacitor is used for smoothing, but can it be used for rectification alone? How would I configure it? I understood that if you tune a cap to a inductior it zeros out, In every rectification method iv seen diodes are used for the rectification process, but how do I rectify a 25kv(low current) ac signal, diodes? where do you find a diode like that? is there a way to maybe make a cheap diode? The best circuit so far is a 555 timer used to drive a ignition coil, but its a pulse circuit, i know i could use a cap for that, but I have a hv transformer which would be better if I could just plug an play it. | |
| btw, would a hv pulse run a lifter, if so it may add more control to it | |
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
| just hook up 12 or so 1N4007's in series to the ouput of the ignition coil.
| so what about if I used a hvdc pulse to charge my lifter, would this work?, has anyone tried, any frequencies ever? another thing I'v always wondered about is a dc pulse that holds no off time, when im analaysing this circuit, it is familiar to an AC signal, with double peak value of course, how similar are theses anyway? | |
| Ok I give up, what's a "lifter"? | |
| if you want a good source of HVDC I would invest in a big vandegraff generator or wiemhurst machine. They are an amperage source rather than a voltage source like many other power sources, and the amperage is quite low, but still easy to make yourself, or buy. | |
Take a look here http://members.iinet.net.au/~pterren/Lifters.htm | ||
| Simple High Voltage Question | grrr_arrghh | General Electronics Chat | 18 | 12th August 2007 11:05 PM |
