Old 14th August 2007, 02:45 AM   (permalink)
Also, search a site for tips and tricks. On Aaroncake.net, he has a page devoted to "how to solder". STOP SPAMMING
Krumlink is offline
Old 14th August 2007, 04:23 AM   (permalink)
Some soldering tips
http://www.elexp.com/t_solder.htm
Bill
Smart Kits build Smart People
Old 14th August 2007, 05:22 AM   (permalink)
I have a small 120mm 12V DC computer fan beside the soldering area.
Otherwise when I’m soldering all the soldering smoke comes to my face. Due to fan it’s all going away from my face. Otherwise I have to use breathing apparatus
Who knows this soldering smoke harmful to the body or not. Shopkeepers selling those are not harmful & lead free ones but who knows………
So I always use my fan.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 14th August 2007, 06:48 AM   (permalink)
What I am going to do is to Put a large tube fan (computer fan) inside one of those dryer air ducts (the springy metal ones) and have one side sucking air out and the other exhausting air outside.
Krumlink is offline
Old 14th August 2007, 03:10 PM   (permalink)
The smoke can be harmful, but not usually because of the lead. Lead doesn't vaporize until its temperature is in excess of about 800 Celsius, well above the typical temperatures used when soldering.
Any health effects is primarily caused by the flux vaporizing, which is a potential carcinogen (I interpret this to mean that there is no proof that its carcinogenic, but it hasnt been specifically studied). Prolonged and repeated contact can cause skin irritation (dermatitis), or if you breath in enough of the vapour it can cause suffocation because the fumes are heavier than air, but more likely you would see other signs before you suffocated (ie, light headidness, shortness of breath, unconsciousness, etc...)
I should really think about setting up a fan or something.. but I usually just dont inhale when the plume of smoke is rising and I only do occasional soldering.
Stellarcore is offline
Old 14th August 2007, 03:18 PM   (permalink)
I was one of the subjects in a government study about soldering, apparently the only concerns of the study were with regard to the possible triggering of asthma attacks in a very tiny percentage of known asthma suffers - caused by the flux vapour.
They were unable to find a single case in the service industries, but there were odd ones in manufacturing, where you soldered 8 hours a day! - their conclusion was that no extraction was required for the small amount of soldering done in a serice environment.
Presumably the same would apply to the amount of soldering done in a home environment?.
So basically, if you want to extract?, fair enough - it won't do any harm, but it won't do any good either!
Basic Soldering & Desoldering Guide ElectroMaster Electronic Theory 15 13th November 2008 01:23 PM
Current flow Vs electron flow, which were you taught? Leftyretro General Electronics Chat 11 13th June 2007 04:18 PM
hot air soldering patroclus General Electronics Chat 18 25th October 2006 12:57 AM
Hotair Soldering Desoldering Guide or Tutorial is Needed xpacer General Electronics Chat 1 20th October 2006 06:56 PM
Soldering Station Confusion TekNoir General Electronics Chat 16 1st May 2005 05:49 AM
