Old 10th August 2007, 09:20 PM   (permalink)
Default This what i confusing with UM66s.
I need help that clarify the pins of UM66T IC. From my research of datasheet of this IC, some stated differently as in pin 1 is pin 3? pin 3 is pin1? I'm kinda confuse from reading the datasheet. Here's the example, please help. Appreciated!!
xiaobai00 is offline
Old 10th August 2007, 09:23 PM   (permalink)
I don't know, I've used one about 10 years ago and I didn't have any problems.
Perhaps you should ask your supplier.
Screen name: Aloone_Jonez
Hero999 is offline
Old 10th August 2007, 09:29 PM   (permalink)
so whats yr view of this? What will you choose? Option 1 or 2?
Old 10th August 2007, 11:46 PM   (permalink)
I don't know, toss a coin.
How could I possibly know better than you?
How many of these units do you have?
Try Googling, look at other datasheets, what's the most common pin-out?
Perhaps you could connect one up with the lowest voltage it will work at with a small resistor in series to llimit the current. If it doesn't work, change the connections then if it still doesn't work try another device. If you've only got one device then it's hard luck as you've got a 50% chance of destroying it.
I would guess option 1 so perhaps you should try it first but I can't promise anything.
Hero999 is offline
Confusing capacitor markings ThermalRunaway General Electronics Chat 7 6th July 2007 02:29 PM
Confusing with this text... Pls help powersys General Electronics Chat 4 11th January 2006 04:25 AM
vibrating cd cover trimard Electronic Projects Design/Ideas/Reviews 7 8th June 2005 01:47 PM
getting confusing 2camjohn Micro Controllers 8 11th April 2004 08:07 PM
