Old 8th August 2007, 08:40 PM   (permalink)
Default Using Polarized CAPs in AC
Hi:
I am just wondering what will happen if I connect an electrolytic polarized cap to an AC line.
I know that connecting the wrong polarity to a polarized cap might cause it to explode, and in AC, the polarity is changing all the time.
Thanks.
joe_1 is offline
Old 8th August 2007, 08:49 PM   (permalink)
Did you just not answer your own question?
dknguyen is offline
Old 8th August 2007, 08:56 PM   (permalink)
I have very good "theoretical" idea about what will happen, so it is some sort of confirmation that I was looking for.
joe_1 is offline
Old 8th August 2007, 10:58 PM   (permalink)
Explosion kind of depends on the voltage rating of the capacitor...
HarveyH42 is offline
Old 9th August 2007, 02:45 AM   (permalink)
There is a way.
By connecting two electrolytic polarized caps in series with + to + and input and output using the negative leads, one can use the resulting capacitor in a AC circuit. Of course the total capacitance will be less then either individual value. Two 10mfd caps in series will present a 5mfd value, calculated just like having two resistors in parallel.
Edit: You still have to spec the working voltage of the caps to the application voltage.
Lefty
Leftyretro is offline
Old 9th August 2007, 05:14 AM   (permalink)
Robot builder 101
mfd? Do you mean uf (microfarad)? You have that posted as millifarad.
Old 9th August 2007, 08:36 PM   (permalink)
Some older publications use m to stand for micro which is pretty silly in my opinion, but it's only used for capacitors which aren't normally found it values as high as 1mF so it doesn't cause too much confusion. I never use mF, I normally use µF for values =<99,999µF and Farads for values >=0.1F, that way I never get confused.
Screen name: Aloone_Jonez
Hero999 is offline
Need advice about this AC Line Current Detector Avocado Electronic Projects Design/Ideas/Reviews 6 21st March 2008 06:37 PM
Polarized and Non Pol capacitors Badar General Electronics Chat 6 19th February 2007 08:45 AM
Electrolytic caps and heat Screech General Electronics Chat 5 12th May 2005 08:30 PM
Huge Cap's bryan1 General Electronics Chat 9 30th January 2005 08:41 PM
polarized caps ericbirecki General Electronics Chat 9 20th November 2004 08:18 AM
