Old 8th August 2007, 06:27 PM   (permalink)
Cool 74LS90 Counting odd numbers only
I'm building a timer with eight 74LS90's in series counting down by ten from either 100KHz or 1KHz. For some reason, the fourth digit counts 1,3,5,7,9,1...
I have several .1 bypass caps at several points on the CB across +5V and ground, but not one on each '90. Has anyone seen this strange behavior?
Joel Sparkman is offline
Old 8th August 2007, 08:36 PM   (permalink)
Default 7490
Check that there is no contact bounce on the clock input, even though it is the 4th digit.
Check soldering between output of 3rd digit and input to 4th digit.
Check the jumper between terminal 1 and 12 to make it count as a ten instead of a five counter.
Are all your R9 1-2 and R0 1-2 at the correct level ?
RODALCO is offline
Old 8th August 2007, 08:40 PM   (permalink)
I think this could be caused by applying the clock from the 3rd chip to the B input of the 4th chip, instead of the A input. If the A input is not clocked, the A output could be stuck at a logic "1", causing the count to be 1,3,5,7,9, as described.
Ron (aka Rube)
Roff is offline
Dual counter bananasiong Micro Controllers 45 24th March 2007 03:49 AM
Weird 74LS90 counter problem Torben Electronic Projects Design/Ideas/Reviews 11 8th December 2006 10:07 AM
Error counting Hesam Kamalan Micro Controllers 3 27th July 2006 12:09 PM
74LS90 narsil General Electronics Chat 3 15th July 2005 01:54 PM
Problem with 74LS90.. some help please?? patroclus General Electronics Chat 9 18th November 2003 03:26 AM
