| I need to design a system that takes a user input that can be displayed on a 7 segment display and the number needs to be stored as a binary number. [hopefully in the form of a hundreds, tens, ones input - can be held down to reach a desired number.] I was going to use this as a template: http://www.electro-tech-online.com/e...ase-10-a.htmlv or use this PIC tutorial on using 7 segment displays Tutorial 10 Main Board, 7 Segment LED Board. How to use dual 7 segment LED's. however i beleive its beyond my scope. I know i need to use a couple of IC's but where do i go about reading up on the required IC's needed for the design. Any help would be greatly appreciated. | |
| If you use the PIC method from my tutorial you don't require any other IC's at all, the PIC can easily (VERY easily!) do it all. | |
| nigels got it right there, although what experience do you have with the PIC programming system? in honesty im still learning how its supposed to work, i get the assembler language but i still dont understand how the configuration bit at the start works! | |
| Not much experiance really - i know a bit of assembly and have done extensive work in C. I'l look into your turtorial. Btw what kind of PIC do you use, a motorolla 68H11, 68H12, mitsubishi? | |
| sorry i just had some silly trivial questions If i wanted to have a hundreds, tens, ones counter from three buttons - and want to display these on the respective seven segment displays - how would i do this - I'm glancing over the the PIC tutorial however it seems like i can't make the jump from a counter to a 3 seperate counters counting in a different fashion. The PIC also has to store the number in binary - so i enter 153 thats one pulse at the hundreds thats 5 pulses at the tens thats 3 pulses at the ones. how would i go about doing this - seems like basic digital / vhdl design yet getting it done in the microcontroller seems quite hard. any help | |
| 7 Segment Display - Switch Project - Help! | FLCARM1964 | Electronic Projects Design/Ideas/Reviews | 9 | 22nd April 2005 07:48 AM |
| Camera and Display project | Shahzad73 | Electronic Projects Design/Ideas/Reviews | 0 | 26th October 2004 09:32 AM |
| Camera and Display System | Shahzad73 | Electronic Projects Design/Ideas/Reviews | 0 | 5th October 2004 09:56 AM |
