| I am trying to build a stepper motor (from an old floppy drive), using a PC parallel port and ULN2803. To protect the IC, a zener diode is recommended. On some sites I see that the diode's anode is connected to +12V: http://www.doc.ic.ac.uk/~ih/doc/step...2/connect.html while on some others, anode goes to pin 10 of ULN2803: http://http://www.epanorama.net/circ...put.html#input Could you please clarify? Thanks, Dusko | |
| Search this forum for snubbing diodes on A B C & D that direct negative voltages to ground. Forget the zener.
__________________ C:\WHUT ? Beware the asterisk * | |
| ZENNER diodes ANODE must connect to the GND that is 9th pin in ULN 2803A. & the ZENNER diodes CATHODE must connect to + VDD. The back EMF protective diodes are inbuilt with it. To make active the back EMF protective diodes pin 10 must give to the VDD. | |
| Project: DC Motor Control (using a single switch) | arijit18 | Electronic Projects | 16 | 7th December 2008 10:37 PM |
| Please help me to understand how to use a zener diode | FAVahalik | Electronic Projects Design/Ideas/Reviews | 6 | 24th October 2005 10:28 PM |
| DC motor freewheeling diode dimensioning. | Odin | General Electronics Chat | 7 | 13th April 2005 11:27 PM |
| Here is a list of semiconductor prefixes. | TPS | Datasheet/Parts Requests | 0 | 21st December 2003 08:24 PM |
| Identify Semiconductors by prefixes | mixos | Datasheet/Parts Requests | 0 | 10th December 2003 07:56 PM |
