| Hi, I'm using a sensor connected to a amplifier of gain 100... But the output gives me only about 20-50mV Vpeak... How can i make the output to have at least 1V Vpeak? Do i have to add another amplifer? | |
Whats the sensor type/specification, some sensors expect/require certain opa configurations? Eric | ||
| Hi, The sensor is NVE AAH002-02 magnetic sensor... Its a spintronics based sensor... This is the datasheet for the sensor and the amplifier that i'm using, Sensor: http://www.nve.com/Downloads/catalog.pdf Amplifier: http://focus.ti.com/lit/ds/symlink/ina118.pdf How do i check whether its possible to increase the gain of the existing one? S.K | |
| Using the gain formula from the IC data sheet, G = 1 + 50k/Rg, if you make Rg = 50 Ohm, the gain will be 1000.
__________________ Len | |
| I see... But how do i know whether the Vpeak will be at least 1V? Isit if i get 20-50mV now using 100 gain, i multiply it by 10 to get the gain of 1000? Than i will know the value of Vpeak using the gain of 1000? | |
As Len says, use a 50R gain pot, this will give an overall gain of 1000. If you got 50mV peak at *100, you should get 500mV at *1000. What are you going to do with the 500mV signal? If you must have a 1Vpk signal, then add another non inverting OPA to the output, a gain of *2 should give you 1Vpk. Or use a 25R gain pot setting for a gain of 2000. Check the datasheet for the Vout limits at a gain of 2000!! What sensor bridge excitation voltage are you using? Eric. Last edited by ericgibbs; 7th July 2008 at 12:21 PM. | ||
| Hi, Oh... Thats how i get the value at gain 2000.... But i cannot find the Vout limits in the datasheets for gain of 2000... Isit in the electrical specs? Quote:
S.K | ||
Its a wheatstone bridge configuration according to the datasheet, the supply voltage is the bridge excitation voltage. The output sensitivity of the sensor is rated as mV/Volt. What is the supply voltage to the sensor and to the OPA? Eric | ||
| Hi, Quote:
S.K | ||
As the datasheet explains, the device is ratiometric and the mV output sensitivity is proportional to the supply voltage. Using a low 3V supply, will give a low sensitivity. Is it possible that you can use say,+5V to the sensor and OPA in order to increase the sensitivity? The sensor voltage max is +/-12V. Eric | ||
| Hi, So the higher the input voltage, the larger the ouput voltage peak? S.K | |
Try it and see the effect. Last edited by ericgibbs; 7th August 2007 at 10:47 AM. | ||
Looking thru the datasheet for the sensor states minimum mV/V is 7.5mV/Oersted and maximum mV/V is 13mV/Oe. So with your original Vsupply of 3V, you should get an output from the sensor of min=22.5mV and max= 39mV [for 1 Oe] As your original Gain was 100, this should give an output from the OPA of 2.25V or 3.9V???? [for 1 Oe] The linear range of the sensor is 0.6 to 3 Oe. Your value of 20mV thru 50mVout would suggest that there is something wrong with the circuit, do you have a diagram? and which magnetic field are you measuring? Eric Last edited by ericgibbs; 7th August 2007 at 11:14 AM. | ||
| Hi, As this is a school project and the design of the circuit is not done by me (done by previous student) i do not have the circuit diagram. I was given the circuit. I'm using the sensor together with a magnet to detect heart rate. But when i use the sensor to detect magnetic field from a permerant magnet, the output is about 1+V to 2+V. It seems that detecting heart rate using the sensor would result in very weak output. S.K | |
| Dynamic mic pre-amp into sound card | systemloc | General Electronics Chat | 52 | 27th September 2006 02:02 PM |
| Lowpass xover with gain and Linkwitz Transform.Gain question | mikee55 | Electronic Projects Design/Ideas/Reviews | 2 | 12th January 2006 10:44 PM |
| Bypass Capacitor sets the gain and AC | walters | General Electronics Chat | 12 | 21st August 2005 06:24 PM |
| Measuring Gain | walters | General Electronics Chat | 14 | 6th June 2005 04:40 AM |
| Variable gain amplification for speakers | h2osman | Electronic Projects Design/Ideas/Reviews | 2 | 26th March 2003 01:16 PM |
