Old 8th August 2007, 06:56 AM   (permalink)
Originally Posted by S.K
As this is a school project and the design of the circuit is not done by me (done by previous student) i do not have the circuit diagram. I was given the circuit.
I'm using the sensor together with a magnet to detect heart rate.
But when i use the sensor to detect magnetic field from a permerant magnet, the output is about 1+V to 2+V. It seems that detecting heart rate using the sensor would result in very weak output.
S.K
The datasheet states that the linear region for the sensor is 0.6 thru 3.0 Oe, so I would imagine the magnetic field from the heart muscle would fall well below this Oe level.
I would expect stray electromagnetic fields from nearby equipment to be a cause of detection problems in the system
You would just get a very weak signal, try to amplify by 2000.
What is the OPA output connected to?, why must it be 1Vpk?
Eric
ericgibbs is offline
Old 8th August 2007, 07:23 AM   (permalink)
I see... ok... I'll try 2000 gain... The OPA is connected to a µC. From the µC datasheet, the min input voltage to the port should be 0.9V and max should be 2.1V.
S.K
S.K is offline
Old 8th August 2007, 07:27 AM   (permalink)
S.K
It appears that the mcu is just detecting the signal as logic low or high, or are you using a mcu with an ADC input?
Eric
Old 8th August 2007, 07:54 AM   (permalink)
The mcu is detecting falling edges of the input signal.
S.K
S.K is offline
Old 8th August 2007, 08:14 AM   (permalink)
S.K
You can use the 'Ref' pin on the OPA to give a positive offset to the output signal, say by 0.5V.
So the 'ac' output signal of 2Vppk, would appear to the mcu input as +0.5V to 2.5V
Old 8th August 2007, 08:50 AM   (permalink)
I see... Thanks for your help.
S.K
S.K is offline
Old 14th August 2007, 06:52 AM   (permalink)
Will it make a difference if i use a 2 stage amplifier circuit? I have tried using a gain of 2000 but in vain. Or do i have to redesign the amplifier circuit?
S.K
S.K is offline
Old 14th August 2007, 07:18 AM   (permalink)
S.K
You can add a further non inverting OPA to the output of the 1st instrumentation OPA. The more stages of amplification you add for a very weak signal, will also amplify any external/system electrical noise.
A simple noise R/C filter between the 1st and 2nd OPA's would be a good idea
What Vpeak to peak signal output do you get with a Gain of *2000?
Is the Vsignal swinging from Gnd/0V and have you added the Vref voltage to the instrumentation OPA?
If the PIC input is looking for a low going 'TTL' edge, ie: +5V to 0V, then you should consider using a Comparator as the
2nd stage connected between the output of 1st stage and the PIC input.
Eric
Old 14th August 2007, 07:50 AM   (permalink)
The output got saturated at a gain of 2000. About the Vref thing, i have not tried it yet. Because the PCB board they provided does not make use of the vref pin. It is shorted to ground.
So if i use the Vref, i have to connect Vref to a voltage source of 0.5V?
S.K
S.K is offline
Old 14th August 2007, 09:28 AM   (permalink)
S.K
What do you mean 'the output got saturated', are you saying in reached almost +5V. So the swing was from 0v thru +5V??
Tell me the minimum/maximum voltage swing on the OPA output.
Eric
Old 14th August 2007, 10:09 AM   (permalink)
Instead of becoming amplified, the output becomes smaller.
The swing was from 0 to 1V.
S.K
S.K is offline
Old 14th August 2007, 10:25 AM   (permalink)
S.K
hi SK,
I would recommend that you use a 2nd stage Comparator after the 1st stage OPA.[1st Gain *1000]
Set the Comparator, using a pot, to switch over when the input reaches say, +0.5V, this will give a +5V edge for the PIC input. [you said the PIC was looking for a low going edge]
Do you follow this explanation
Eric
Old 14th August 2007, 10:39 AM   (permalink)
Using a op-amp without feedback? So the 1st stage op-amp gain will be 1000? Whats a pot?
Sorry, I do not understand.
S.K
S.K is offline
Old 14th August 2007, 11:01 AM   (permalink)
S.K
A 'pot' is a shorthand way of writing 'potentiometer' [ variable resistor]
You can configure a standard OPA to work as a comparator.
Problem is, some OPA's will 'latch up' when used this way.
What OPA's do you have?
EDIT: Look at this pdf
Old 15th August 2007, 02:32 AM   (permalink)
I see...
I only have the OPA that I showed you. INA118.
Do I have to purchase another type of OPA or can I use the INA118 as the 2nd stage OPA?
S.K
S.K is offline
Dynamic mic pre-amp into sound card systemloc General Electronics Chat 52 27th September 2006 02:02 PM
Lowpass xover with gain and Linkwitz Transform.Gain question mikee55 Electronic Projects Design/Ideas/Reviews 2 12th January 2006 10:44 PM
Bypass Capacitor sets the gain and AC walters General Electronics Chat 12 21st August 2005 06:24 PM
Measuring Gain walters General Electronics Chat 14 6th June 2005 04:40 AM
Variable gain amplification for speakers h2osman Electronic Projects Design/Ideas/Reviews 2 26th March 2003 01:16 PM
