Old 5th August 2007, 03:43 AM   (permalink)
Robot builder 101
Lightbulb Plan for simple Press on press off circuit?
I forgot the correct name of the circuit, but I would like to integrate it into one of my upcoming robots. This is how it works:
You press a momentary button (not a tactile, where it depresses) and it turns on the circuit and keeps it on until you press the switch again. What is this called using a momentary switch? does this require a microcontroller?
Old 5th August 2007, 03:52 AM   (permalink)
There have been circuits posted for this in the past - including some by me. Do a search for "flip flop" or "toggle switch".
Len
ljcox is offline   Reply With Quote
Old 5th August 2007, 05:14 AM   (permalink)
Robot builder 101
Thanks, I found one, and I happen to have all the stuff I need there... I think thats a first time ever!
Old 6th August 2007, 09:05 PM   (permalink)
Robot builder 101
Lol, I forgot to write down the site so that I could build it...
I am using a 74HC74. A link would be nice!
Old 6th August 2007, 10:37 PM   (permalink)
Try this one
http://www.electro-tech-online.com/e...ghlight=74hc74
Len
Old 7th August 2007, 02:10 AM   (permalink)
Robot builder 101
I got the circuit working, but I am having trouble with button debounce. any suggestions?
Old 7th August 2007, 02:27 AM   (permalink)
This circuit is simpler and works well. You can have 3 circuits from one IC or use the leftover inverters tin parallel to boost the current. The capacitor debounces the pushbutton.
Old 7th August 2007, 02:32 AM   (permalink)
Robot builder 101
Thanks. Ill test it out right now!
is 47nf a 0.047uf cap? Could I use a 0.1 uf cap?
Old 7th August 2007, 03:18 AM   (permalink)
Robot builder 101
It works amazingly well! The 0.1 cap is a perfect substitute. Thanks!
Old 7th August 2007, 10:42 AM   (permalink)
If you jab at the button very quickly and the supply voltage to the Cmos IC is at 3v which is its lowest allowed, then it might not switch when its capacitor is 0.1uF.
Old 7th August 2007, 06:02 PM   (permalink)
Robot builder 101
I built it with a 5v regulator, then hooked up a 2907A to switch a circuits connection from its negative connection to GND. Pictures up later
Old 7th August 2007, 08:38 PM   (permalink)
Ordinary Cmos doesn't need a voltage regulator. It works with a supply voltage from 3V to 18V.
Old 7th August 2007, 08:51 PM   (permalink)
Robot builder 101
I know, but its fun just to throw one in there.
Old 7th August 2007, 09:05 PM   (permalink)
Well, I was going to help you but audioguru seems to have sorted you out and I don't think I have anything useful to add other than an amusing story (if you have my sense of humour) about a recent application for this circuit.
I modified the side lights on my Land Rover some time ago with green LEDs to match the colour of the vehicle. Took her in for an MOT (that's a compulsory annual test of roadworthyness here in the UK) and she failed for the lights. They're not allowed to be green, they have to be white.
So I took her home, and pondered the situation. I quite like the green glow when the side lights are on and I didn't really want to have to put her back to the original spec. I could Take the green LEDs out, fit white for the MOT and then fit green back in there afterwards but that would be a bit of a drag so in the end I re-modified the light cluster with green AND white LEDs. I hooked them up to a circuit similar to the one AudioGuru has shown here, with a button installed into my dash marked "MOT button". The circuit is powered by constant 12V so it always remembers it's current state.
I took the Land Rover back in for the retest and the mechanic called me over. "These lights are still green!!!" he said. "Push the MOT button on the dash!" I replied, and left him to it. Needless to say she passed, and I drove out with green lights
Childish I know. But hey gotta be done every now and then!
Might think of some more things I can hook up to the MOT button actually. Hmmmm...
Brian
Electronics Test Development Engineer
ThermalRunaway is offline   Reply With Quote
Old 7th August 2007, 09:41 PM   (permalink)
I wonder if you could have a MOT button to select the worn out old brake pads or select new pads to pass the test. Then you drive on the old brake pads until they are completely gone.
Question about HT 8870 in the TELESWITCH circuit !?! zambalik General Electronics Chat 11 6th September 2007 12:11 PM
Power-On delay circuit tzitzikas General Electronics Chat 15 7th June 2007 07:48 PM
555 Monostable 2 second output circuit Help Turbo Boss Electronic Projects Design/Ideas/Reviews 2 3rd August 2003 05:41 PM
close a circuit by 0v switch lazynok Electronic Projects Design/Ideas/Reviews 5 10th June 2003 09:42 AM
help! need to modify a bistable flip-flop circuit.... xxplorer Electronic Projects Design/Ideas/Reviews 1 30th April 2003 03:38 AM
