Old 4th August 2007, 05:42 PM   (permalink)
Question "Spy Kids" console - LEDs
I have been tasked with designing a "spy kids"-like console with radar images, flashing lights, working switches, etc. I have the pc parts figured out, but am a novice with electronics - last time I built a circuit board was as a kid.
Wanting to setup a few simple flashing LED panels with off\on switches. Have found a few places that sell 12V flashing LEDs.
http://www.vellemanusa.com/us/enu/pr...iew/?id=349956
http://www.partsexpress.com/pe/showd...number=079-175
My first question is can I use an old 12V power supply scrapped from an old wireless phone base (or one I could pick up at radio shack) to power a bunch of these things? I was planning on cutting the adapter plug off and wiring it straight into some of these with an on\off switch. If that would work - would I wire them in parallel or series? How many do you think could be wired off of 1 standard power supply?
Any advice is appreciated! (Also, if anyone has any simple ideas to add some "coolness" to such a console - that would be awesome too!)
Thanks!
Glen M
GlenMcl is offline
Old 5th August 2007, 04:04 AM   (permalink)
By Power supply do you mean a wallwart aka AC Adapter?
If so, then yes you could use it.
Put the LED's in parrellel, also observe correct polarity.
"The glass is neither half-empty, nor half full, it's just twice as big as it needs to be" - Unknown
andrew12345678 is offline
Old 5th August 2007, 04:37 AM   (permalink)
Thanks! Yes - it is a wall AC adapter. 12V/1500mA. How many 12V LEDs could I conceivably run off of one of these? And could I run multiple parallel circuits off of it? For instance - 3-4 LED panels with x LEDs each and an off\on switch for each panel - each running parallel off the one AC adapter. Is that possible?
Thanks!
Glen M
GlenMcl is offline
Old 5th August 2007, 07:39 AM   (permalink)
to answer that you would need to know how many mA each LED needs.
most red LEDs need 20mA, but im not too sure about these, because they run at a much higher voltage and may have a flashing circuit in the casing.
asuming they do run at 20mA you should be able to run 75, although i wouldnt trust my calculations.
yes, you could run multiple circuits off it, as long as you dont exceede the maximum ratings of the supply.
Old 5th August 2007, 08:01 AM   (permalink)
hi Glen,
Have a look at this link.
http://www.kpsec.freeuk.com/components/led.htm
You should not connect LED's directly in parallel, each 'parallel' LED requires it own resistor.
As you have a 12Vdc psu, I would suggest series connection of the LED's would be the most efficient.
Eric
ericgibbs is offline
Old 5th August 2007, 08:57 AM   (permalink)
if you wired 12 volt led's in series, wouldn't you have to have a higher voltage? if you wired 4 led's in series on 12 volts, each led would see 3 volts, but if you had say 7, each led would see 1.7 volts, which isn't enough for yellow's, blues, whites, greens and all the others except for red. right????
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 5th August 2007, 11:03 AM   (permalink)
hi things,
If you look at the link I posted for Glen, you will see the majority, if not all common LED types fall within the 1.5v thru 5v voltage band.
Eric
Old 5th August 2007, 11:25 AM   (permalink)
Thanks!
Glen M
You can get simple multicolour flashing leds that would look impressive, some cycle through red,green, blue quickly and others slowly blend the colours.
Have a search on ebay, usually China based suppliers have them in various quantities and cheap.
picasm is offline
Old 5th August 2007, 11:44 AM   (permalink)
Hi picasm,
The colour cyclic LED's are called 'rainbow' LED's, if you want to refine the search.
Eric
EDIT:
http://www.bit-tech.net/modding/2002.../rainbow_led/1
http://www.goldmine-elec-products.co...?number=G13897
Old 5th August 2007, 09:36 PM   (permalink)
I'm looking at using the 12V flashing LEDs from here:
So from what I understand if I put several of them in series I would require more than 12V power. But to put them in parallel each LED would require a resistor? That sounds like the way to go I suppose. What kind of resisters would I need?
Thanks all!
Glen M
GlenMcl is offline
Old 5th August 2007, 09:59 PM   (permalink)
Just hook them up in parallel to a 12VDC wall wart, 500ma is common and should be enough for a couple of dozen of those flashing LEDs.
Bill
Smart Kits build Smart People
Old 6th August 2007, 07:27 AM   (permalink)
Thanks all!
Glen M
Hi Glen,
I don't know how many flashing LED's you are planning, but the flashers in the link will be an expensive way to do the project if you use more than one or two.
It would be possible using a simple pulse generator [555 or equiv] with a couple of logic ic's, using budget LED's to give flashing and LED sequencing.
Eric
EDIT: using the flasher in your link, its already got internal resistors/etc, so these parallel flashers dont need resistors.
Look here:
http://www.glowsticks.co.uk/acatalog...NOVELTIES.html
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! Ocelaris Electronic Projects Design/Ideas/Reviews 12 31st December 2006 07:18 PM
A Basic Question of Efficiency - 4 LEDs in parallel or series!?! Agent M Electronic Projects Design/Ideas/Reviews 9 27th December 2006 04:23 PM
Long-life circuit for LEDs and a clock dabuttery Electronic Projects Design/Ideas/Reviews 4 22nd February 2006 04:16 PM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 05:55 AM
