| Hi, I've done tested this boost regulator IC according to the datasheet. http://www.linear.com/pc/productDeta...31,C1060,P1897 ![]() but I just modified the output voltage to be almost 5 V by changing the resistor value, so that I can use it for my LCD display. With no load, the output is almost 5 V. When the battery is fully charged, it can power up the LCD and a PIC for hours (I'm not sure how long, just leave it there, maybe just 1 hour). When the battery drops to 1 V, it lasts for only a few second Maybe the design is for 3.3 V output only. I've measure the current drawn by the LCD and the PIC, it is not more than 2.5 mA. Just wonder is there any way to improve the running time? BTW, I'm using a sony rechargeable battery, 2500 mAh. ![]()
__________________ Superman returns.. | |
| Hi Banana, It is not working properly. Maybe you forgot to connect pin 2 to the positive input voltage. Then with a 2.5mA load it is 87% efficient so the 1.2V input will have a current of only 11.8mA. Then a fully charged 2500mAh cell should last about 212 hours.
| | (permalink) | ||
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 31st July 2007 at 02:43 AM. | |||
| I am at the top of a tall ladder in the dark with my flashlight powered by Ni-MH cells. My flashlight suddenly dims when its battery cell voltage drops to 1V and lower. Then I can't see anything.
| Most likely you not putting PIC to sleep are you running the pic constantly or do you shut it down (not sure if PIC have sleep but going by AVR/atmel) active currents are quiet high remember also set unattached inputs to a level either with pull ups or pull down (another source of heavly power consumption floating pins) | |
| Hi, Thanks for the response OMG.. I've seen the schematic wrongly. audioguru got it, I've connected the pin 2 to ground, but I've simulated with LTSPICE, both also working. And the datasheet recommends this pin to be high after the part has started up. I've made 4 PCBs for this and burned one IC For the diode, I'm using Schottky diode 1N5817 while for the capacitors C1 and C2, I'm using only electrolytic type. Is there anything to do with the max current sourced by the battery? I know that there is internal resistance in the battery, but it is not measurable.
__________________ Superman returns.. | ||
| | (permalink) | ||
| The datasheet says to use very low ESR capacitors like tantalum or ceramic. Your electrolytic caps are horrible at the high frequency of this voltage converter due to their high inductance (they are wound like a coil). Try adding a 0.1uF ceramic disc capacitor with very short leads at the input and output in parallel with your electrolytic capacitors. Maybe your inductor is too small and is saturating?
| | (permalink) | ||
BTW.. the multimeter is working Quote:
I think I'm using the ceramic or carbon type inductor (resistor looked inductor).
__________________ Superman returns.. | |||
| Your inductor might be an RF choke. Then it will have a resistance too high and a saturation current too low.
| | (permalink) | ||
| Which one is correct? I just googled ferrite coil and found these: and![]() I think the green color is the RF choke. Parts are really difficult to be got over here, as long as they got the value, the rest they don't care
| Pic 877A and boost converter | williB | Micro Controllers | 15 | 4th May 2007 03:14 AM |
| IRF 740 Drive circuit for Boost Converter | bdvs | Electronic Projects Design/Ideas/Reviews | 3 | 11th April 2007 10:52 PM |
| Boost Converter Schematic Comments? | William At MyBlueRoom | Electronic Projects Design/Ideas/Reviews | 6 | 18th May 2006 07:38 PM |
| boost converter | geronimo | Datasheet/Parts Requests | 2 | 17th May 2005 10:56 AM |
| boost converter | ee01akk | General Electronics Chat | 1 | 13th April 2004 07:52 PM |
