Old 28th July 2007, 01:55 AM   (permalink)
Default Volume pot and leds.
My goal is to use one pot controlling the audio volume and having some leds around the pot knob turning on or off if i turn the pot to max or min. I want to use 6 to 10 leds to increase or decrease like a vu-meter ( but not blinking with the audio signal ) according to the Vol.
Sorry my bad English. I hope you understand this !
I thought using a stereo pot, one part of the pot will control the audio volume, the other will make leds go on or off, but i donīt have a clue how to do it !
Thanks.
Samycasanova is offline
Old 28th July 2007, 02:58 AM   (permalink)
Well why not use a stereo pot and one part of the resistor would control the input current into an LM3915 or a similar model...that one is logarithmic...which MIGHT be what you want.
http://www.national.com/mpf/LM/LM3915.html
That drives 10 leds...and it's how I would do it. Remember the pot will probably have to be logarithmic because sound is. The component would have to be anti-logarithmic almost... It also supports dot and bar mode.
TrevorP is offline
Old 28th July 2007, 09:39 AM   (permalink)
Well at the risk of a non-electronic solution?, why not have a ring of ten LED's lit all the time, and have a solid disk with a hole in it attached to the knob. As you rotate the knob the hole in the disk moves along the LED's, allowing each one in turn to be seen.
Old 28th July 2007, 03:21 PM   (permalink)
You could use a wafer switch attached to the shaft of the volume control.
CheapSlider is offline
Old 30th July 2007, 09:37 AM   (permalink)
I though using something like that but i donīt know how can i use a regular 16mm or 24mm pot like this one http://www.mouser.com/search/Product...alkey31VC303-F , and use one of those wafers...
I put most of my circuits in tiny enclosures, using a potentiometer with a longer shaft is not a good solution for me.
