okay, so the title probably didn't make sense. I wasn't sure how to explain it in such few words. anyways, here's my problem: -I have a barometer sensor that gives off a voltage range of 0.2v-4.8v, a direct correlation to pressure (15kpa-115kpa), to an ADC (0-5v) -Most of the data from the barometer is useless... so that I don't waste any of the ADC bits (and to get more accuracy), I'd like to chop off the voltages from 0.2-2.5v, leaving 2.5v-4.8v, and spreading that over a 0-5v spectrum... Is this even possible? Thanks! | |
hi, I provided a a fellow rocketeer with this circuit, he had the same requirement to measure altitude/pressure. He has built the circuit and it works OK. It uses a AD623 opa, the Vref could be simplified if required. Lets know if this what you have in mind. EDIT: are you using the MPX4115A or MPX6115 sensor? Eric Last edited by ericgibbs; 7th July 2008 at 12:21 PM. | |
Eric, Thanks for the quick response. I'm using the MPX4115. That circuit looks pretty complicated.. Is it difficult to explain? Thanks Matt | |
| | #4 | |
I have attached the zipped text of some emails from/to the other rocketman. They should answer some of your questions. If you would like to contact the other guy, send me your email address in an email to me, I will forward it on. Eric Last edited by ericgibbs; 7th July 2008 at 12:21 PM. | ||
| magnify, range, sensor, voltages |
| Help with PIR Sensor | garyi | Electronic Projects Design/Ideas/Reviews | 7 | 1st February 2007 09:44 PM |
| Z8 Encore Error index out of range | mootaccount | Micro Controllers | 2 | 17th October 2006 03:23 PM |
| Ultrasonic range sensor | MrMikey83 | Electronic Projects Design/Ideas/Reviews | 2 | 11th February 2005 07:03 AM |
| Massive ERRORS in program. URGENT HELP NEEDED. | davepusey | Micro Controllers | 8 | 18th May 2004 05:13 AM |
| proximity sensor : low range | ikalogic | General Electronics Chat | 7 | 3rd April 2004 05:33 PM |
