| hi guys , I have found a ckt on ezone that can help us control electronc appliances using a pc.....it says that it can be done by controlling the parallel port of the pc .......anyone pls tell me the merits and demerits of the ckt....the link below has the full details of the project......http://www.electronic-circuits-diagr...tersckt1.shtml ![]() | |
| hi, The circuit should work OK, I see they also provide the program for the PC. If your PC, OS is Windows XP you may require to download one or two *.dll's in order to control the parallel port. BTW, that image you have posted contains a cookie! | |
| mr.gibbs if have tried this before can u give me the details of ur project | |
What devices do you want to control? | ||
***** hello sirs, Im a graduating student, and our group have this for our final project. Although, its not really the exact copycat because we are using required to use PIC on in, and one of my instructors said that we must also be able to control the devices by a manual switch. We are using the serial port to send data to the PIC. Now I have this idea of using a keypad for the manual manipulation of the devices. The manual switch is a need because we will be using a LAN connection, and its (the manual switch) an advantage if the server is down. See, the concept is to monitor and control the aplliances of a small building. And then my question(s) Whats the advantage of using RS232 over RS485, we only have to present minuture of the whole system. Can anyone of you give us idea how to put up the manual switch? Can we use a keypad for this( the switch)? Were controlling atleast 4 devices in each room. Our group is composed of 3 female seniors and we only have less than 4 months to accomplish this. I would appreciate your suggestions... | ||
| generally ...as per the project that is given above power supply to any device can be controlled using the relay....i wanna use this circuit to control any device by controlling its powersupply | |
Please open your own thread, your topic is different from the OP's query. | ||
As it required to operate the relay for your device, why dont you use the circuit you have posted? | ||
| i want to use the circuit that I have posted ....but i wanna know if the circuit is tested by someone else ...can u tell me if this circuit works fine .....and also pls tell me list of dll files needed to download to allow windows xp to configure the printer port | |
As I said, the circuit looks OK. The two dll's I would get are: INPOUT32.DLL and DLLPORT.DLL Eric | ||
| thanks for the concern .......and one more thing is there any chance of my computer being spoiiled because of hign voltage or any thing like that | |
For a small load a small Relay will be ok but for a large load you must choose a big Relay according to the current drawn by the AC mains. Also don’t forget to put the Back EMF protecting diode. | ||
If you want to test your PC's parallel port control, without the complete circuit, make the circuit marked in RED. If you have a meter you could measure the Voltage on the output pin, about +0.4Vlo and +4Vhi. Do you have a port test program? Have attached a zipped test program, exe and source. You require the free Visual Basic runtime files, from the web, to run the *.exe Last edited by ericgibbs; 7th July 2008 at 12:21 PM. | ||
| mr.gibbs can u tell me if i can use an 150ohm relay in lieu of the mentioned 100ohm ....and when i tried measuring the voltage across the parallel port it showed a value of 4.5volts all the time there is no change in voltage | |
| gayan ....can i use a 150 ohm relay if i want to light up a 60watt bulb Last edited by nightcatz; 18th July 2007 at 03:56 PM. | |
| What appliances apply to Electronic card lock project? | xiaobai00 | Electronic Projects Design/Ideas/Reviews | 15 | 29th May 2007 01:45 PM |
| Hello, I'm new to Electronic circuits, how do I get info. on electronic tach for m.c. | pwotoole | General Electronics Chat | 17 | 16th May 2007 06:33 AM |
| Zero Signal audio switching | gtrdude | General Electronics Chat | 12 | 12th November 2006 08:28 PM |
| manual switching to electronic | MrBugs | Electronic Projects Design/Ideas/Reviews | 4 | 24th January 2005 12:15 AM |
| convert a manual switch to an electronic switch | dolphin | Electronic Projects Design/Ideas/Reviews | 1 | 1st September 2003 06:04 AM |
