Old 12th July 2007, 07:46 PM   (permalink)
Default Circuit fuse for lipo alarm
So, i ordered some maxim sample chips for my lipo alarm and put together a strobe light set for my helicopter using a pic 12f629. I dont have a schematic just yet to post, im heading out the door now anyway, but ill post one soon if needed.
I plan to run the lights off the extra receiver channel on my heli. It puts out a 5v current and works just fine. My only concern is that if something were to short, for whatever reason, it could fry the reciever. Ive fried my mixing board once and it happens fairly easily!
I dont really see this happening but......
How can i protect the receiver from shorts, wherever it may occur, in the circuit. Would a diode inline from the receiver work? I dont want a full on fuse, as it will negate the small design (its about the size of a nickel). Or possibly a resistor of some sort....or better yet, an actual "micro" fuse...
samtheboxer is offline
Old 12th July 2007, 08:46 PM   (permalink)
A simple series resistor is all that's needed, it's only a low level signal output, you can't draw any amount of power off of it.
Old 12th July 2007, 10:01 PM   (permalink)
Is the circuit controlled by this line from the receiver, or powered by it, or both?
If it's just controlled by it, Nigel's resistor is a great suggestion ... 1k or higher will limit the current to a "do no damage" amount
If it is powered by the receiver, you could use something called a "PTC" or picofuse. they're thermally activated fuses that clamp down on current when too much flows. they're also self resetting.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
simple fire alarm circuit ideas???? nandu Electronic Projects Design/Ideas/Reviews 6 5th August 2006 06:55 PM
i need helpin an alarm circuit doda16eg Electronic Projects Design/Ideas/Reviews 4 27th July 2006 12:30 AM
Activating a circuit using a photocell mtrails Electronic Projects Design/Ideas/Reviews 5 10th May 2006 06:13 AM
Burglar Alarm System Circuit johno Electronic Projects Design/Ideas/Reviews 7 20th March 2006 02:27 AM
Help with sounds alarm after 30sec w/ battery saver circuit DaKandEKid Electronic Projects Design/Ideas/Reviews 2 1st September 2003 09:31 PM
