Old 12th July 2007, 05:13 AM   (permalink)
Default Power Supply Question
Hi!
My question is one about a power supply.
First, I just want to give you a quick background about my project.
I have assembled 4 separate electronic LED light boxes, each of which in their original state were powered by an Input 120 VAC 60 hz 12w with an output of 8v AC 1 amp power adapter into one unit by joining the internal power cords of each unit together.
My question is~~~
What power adapter would I need to power the now 1 unit safely? (in terms of electrical requirements)
Thank You,
Graham
brittam is offline
Old 12th July 2007, 09:54 PM   (permalink)
LEDs ideally require a constant current supply rather than a constant voltage supply.
Using a resistor in series with the LEDs is alright for low power levels if you're not bothered about efficiency.
More information is required here, at the very least you need to give:
Forward current?
Forwars voltage?
The above can be found from the datasheet; if you don't have access to this then you can normally estimate it from the colour of the LEDs. This can be found from Wikipedia:
http://en.wikipedia.org/wiki/LED_circuit
Screen name: Aloone_Jonez
Hero999 is offline
Using a LM2679 for a power supply, question about ratings FusionITR General Electronics Chat 8 22nd February 2008 11:03 PM
power supply question iONic Electronic Projects Design/Ideas/Reviews 7 2nd June 2007 03:45 AM
power supply question raphaelriv General Electronics Chat 3 21st May 2007 09:33 PM
OP2134 Power Supply Question gramo General Electronics Chat 9 14th May 2007 03:36 PM
POwer question. Im using power from micro and seperate one cubdh23 Micro Controllers 3 25th April 2004 01:03 AM
