Old 11th October 2007, 11:42 PM   (permalink)
[quote=hardcore misery]question: mr.AG, does the Vref is set at the -feedback through R1 and R2?[quote]
It is not feedback. It is the reference voltage for the comparator. Select R1 and R2 to make 28.5mV plus and minus a little hysteresis.
i'm just confused because i'm trying to compare this schematic to the attached one, why did you add another resistor at the +feedback, is it to divide the Vdrop from the current sense resistor? where is the Rh now on the circuit?
Without my added resistor then the value of the R7 hysteresis resistor will be so low that it will overload the comparator's output.
Old 12th October 2007, 01:00 AM   (permalink)
[quote=audioguru][quote=hardcore misery]question: mr.AG, does the Vref is set at the -feedback through R1 and R2?
private message sent..
hardcore misery is offline   Reply With Quote
Old 12th October 2007, 05:34 AM   (permalink)
mr.AG please confirm if the schematic is now correct...
the Vref of the -input was set to 31mV
the hysterysis was used at the +input, so that if the voltage drop is 0.0575, at 4.13V, the charger shutts off then the Vinput(2.13mV is lower than 31mV)at the +V will decrease to 1.21mV due to not charging condition...
so the pushbutton will serve as a trigger for the comparator to charge the battery, once the pushbutton connects the relay, the Vdrop is sensed at the +input and the comparator turns ON, then the pushbutton must released, in other words, the pushbutton is pushed quickly,, we can you toggle switch mr.AG? toggle the switch ON, then switch again it to OFF.. are these correct?
Old 12th October 2007, 02:20 PM   (permalink)
Remove the capacitor at the (+) input of the comparator. You want the hysteresis to change the voltage here as fast as possible.
Hysteresis? There won't be any hysteresis because the output saturation voltage of the comparator is about +120mv so it never goes low enough to trip the hysteresis.
I fixed it:
1) I added an opamp to amplify the 28.5mV from the 1 ohm current sensor to +410mV. +410mv is halfway between +120mV and +700mV.
2) The reference voltage for the comparator should be +410mV.
3) I added a diode at the output of the opamp to limit its output to +700mV.
The LM358 opamp is a dual opamp. Use the other half as the comparator.
Old 12th October 2007, 04:39 PM   (permalink)
I fixed it:
what about the revised schematic i've posted above, is it not impossible to use that circuit? FYI mr.AG it's already 1:00am here and our final defense starts on 11:00am, all electronics shops are closed now, its midnight here... so the pushbutton on the revised circuit iv'e posted is now useless? and the circuit itself is useless? the only way for us to pursue your schematic is for us to request a reschedule of our final defense of my group only, or to move it in the afternoon, if we are lucky that our prof. granted our request, that's good for us, BUT this schematic you've suggested is really a 100% working? if then, we will try our luck to make a request to our prof..
Old 12th October 2007, 04:44 PM   (permalink)
I fixed it:
do we still need a pushbutton for this circuit? if i will use a TL072, or a JRC4560, are there changes on the voltages? if it is given that we pursued your schematic, can we have the computations and formulas used on your schematic( and a lot of changes on the documentation should be fixed )
Old 12th October 2007, 05:33 PM   (permalink)
I don't know if my schematic works. If I want a battery charger then i simply use a battery charger IC that works perfectly.
I used an LM358 opamp because it s inputs work at 0V and its output goes down almost to 0V.
The inputs of a TL072 stop working below about 2.5V. Its output goes down only to 1.2V. I couldn't find the datasheet for the Japanese dual opamp.
Try your latest circuit without the 0.1uf capacitor and without the hysteresis feedback resistor. It might work or the comparator might oscillate when it reaches the threshold.
Any of these circuits need the pushbutton to start them.
Old 12th October 2007, 06:42 PM   (permalink)
tried the circuit, it only lights up the LED and does not turn ON the Relay, (that is when i connect the 9.4V to the GND, but connecting the collector to the emitter won't turn on the comparator
Old 12th October 2007, 08:57 PM   (permalink)
Which circuit?
When the pushbutton shorts the transistor then LED should light and the relay should turn on. The relay should stay on when the pushbutton is released if there is a Li-Ion battery charging in the circuit.
Old 26th January 2008, 02:48 AM   (permalink)
if the battery is in the cellphone when the battery is being charged, you need the charger for that phone and it does it automatically, i assume, because i upgrade to another phone 3 times, and they all did it automatically
Every little bit counts! It works with money, and it works with electronics!
bunghole is offline   Reply With Quote
Old 10th February 2008, 10:49 AM   (permalink)
Guys I really need your help with something here if you can,
I need to adjust this circuit so that it will work on charging a 7AH battery (cealed) now the thing is i read that the vcc for NE555 can be 16 V so I am planning on supplying this circuit with 14v DC so that I can use it for charging the 7AH 12 V battery, i must change the zener to a more value but i need more current for charging I think 800 ma is enough , what do you think could I do that with a triac instead of using the transistor in the diagram ?
could anyone give me a solution by changing some compenonts in the circuit to fix this problem
adnan_m_s is offline   Reply With Quote
Old 10th February 2008, 05:42 PM   (permalink)
Hi Adrian,
You attached a charger circuit that is 100 years old. Cell phones stopped using Ni-Cad batteries many years ago.
It charges a Ni-Cad battery, not a sealed lead-acid battery.
Old 10th February 2008, 06:36 PM   (permalink)
http://www.electro-tech-online.com/g...equired-2.html
Please don't post the same question in many threads as it only confuses things.
Screen name: Aloone_Jonez
Old 11th February 2008, 08:11 AM   (permalink)
will the last diagram work for 12V 7ah Cealed battery
Old 12th February 2008, 08:19 PM   (permalink)
No, as audioguru has already stated, it's designed for Nicads and not lead acids.
Lead Acid battery charger manojp01 Electronic Projects Design/Ideas/Reviews 5 29th January 2008 05:16 PM
Battery charger help... dieselmo34 Electronic Projects Design/Ideas/Reviews 14 18th December 2006 05:30 PM
Cheapo battery charger auto shutoff? Iceman_Chris General Electronics Chat 3 21st November 2006 06:01 PM
Battery charger for mobile phone Motorola 2PAC Mafia General Electronics Chat 0 4th October 2005 03:19 PM
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 0 4th January 2005 09:35 PM
