| Keep god out of it. God might mess up your project. Sleeping now? It is early in the afternoon here. You must be in the Soviet Union, China or India.
| Mr.audioguru, i've realized that setting the Vref at the -feedback, and setting the Vsense at the +feedback is useless, because at NO LOAD condition, the Vsense is ZERO, which makes the comparator OFF, even there's a battery with 3V, the Vsense will be also zero, beacuse the battery is not connected to the charger, Unless there's still a Vsense eventhough the charger is not connected to the battery, the Vsense is in between the - terminal of the battery and the limitting resistor, is there a Voltage at that point, even there's no charger connected to the battery? | |
| If there is no battery in the charger then the current is zero and the charger won't begin to charge when a battery is inserted into the circuit. So simply add a pushbutton that flips the relay so it can begin charging. Then when the charging current drops to 10% or 3% of the battery's rating then the (+) input of the comparator is less than the reference at the (-) input and the transistor turns off the relay.
| what kind of pushbutton should we use? tackle switch? | |
| audioguru: Is it really possible to compute for Vref(on state) which is 22mV and a Vref(OFF state) = 0.4V, because we always come up with an equal values of Vref or the Vref for ON state is always greater than the Vref at OFF state... is it possible for the Vref at OFF state to exceed the Vref at ON state? If you don't mind sir, can we ask for your help, to compute for the resistive values needed on the inputs of the comparator.. The Vref at ON state should be 3% of 950maH, and the Vref at OFF should be 0.4(which ables the user to charge a battery with less than 3.8V, or a Vref of 0.5V, which ables to charge batteries with 3.7V or less than 3.7V... the supply voltage is 9.4V + or - 0.1V, Note: Vref is set at the -feedback of the comparator, and the Vsense is at the +feedback | |
| hi hardcore. Can you please post a circuit showing how the components are connected, its not possible to work out the circuit from your text description and mark in the voltage points you are trying to determine.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| Your comparator is used to turn off the charging when the charging current drops to 3% of the battery's rating. Therefore the charger is off when a battery is connected to it. You don't need to detect a Vref as high as 0.4V. 1) Will you use a 10.5V supply feeding a current regulator and a 4.2V voltage regulator in series? How much current? 2) What is the value of your current sense resistor? 1 ohm will limit the current for most of the charging time. 0.47 ohms will be better. 3) Will you use a pushbutton to start the charging?
sorry mr.audioguru for being confused on this circuit... if we put hysterysis on the comparator, there will be two Voltage References to be set on this circuit, the Vref during OFF condition, and the Vref during ON condition of the compatator... for us to charge batteries, for example, a 3.7V battery is to be charge, so to be able to charge the battery, the circuit should satisfy the Vref at OFF condition, right sir? if we need to charge a 3.7V battery, we need a Vref at OFF condition to be set on 0.4V (caused by 4.2V - 3.8V = 0.4V at 1ohm), if we charge a 4V battery(the vdrop is 0.2V which is less than 0.4V, therefore the comparator is OFF) to clarify AG, Vref are set on the -Feedback while the Vsense is at the +feedback... and for us to charge the battery, we need the pushbutton you have suggested AG, question: the pushbutton is connected between the 9.4V and the +feedback, if the pushbutton is pushed, the 9.4V gets into +feedback then it closes the RELAY (Vref = 0.4V) does the comparator senses the Vdrop after the pushbutton is released? if so, then the circuit will now then charge the low voltage battery.. what if we will not use a current regulator? does it take time to fully charge a nearly fully charged battery?(ex.4.1V) if not, if we lower down the 1ohm resistor to 0.5 or 0.45V, does it make faster? please analyse also the Vref of the circuit mr.AG, the Vref at ON state is less than the Vref at OFF state( but looking at the formulas, and after experimentation on getting the necessary input resistors, Vref at ON is always greater than or equal to Vref at OFF state, in example, Vref(ON)=0.028V and Vref(OFF)=0.4V) | ||
| I started to update your schematic to see how you are going to make hysteresis work backwards (impossible), but then I stopped because YOU should update your schematic so we can see what you are talking about. If you use a current-limiting resistor instead of a regulated current then the charging will take forever to reach a full charge. It will take a long time and the battery will never be completely fully charged because it is too simple. I don't know how much is the internal resistance of a Li-Ion battery cell that causes its voltage to rise a corresponding amount immediately when it is connected to a charger. If the battery voltage is 4.1V and you try to charge it then the charger might shut off immediately. The comparator's inputs don't work if they are within about 2V from the positive supply (input common mode voltage) so don't connect an input to the positive supply. The pushbutton should directly turn on the relay to start the charger. But then if somebody holds down the pushbutton when the battery is fully charged it will become over-charged and might catch on fire.
| I see your revised schematic now. Its hysteresis is wrong. Hysteresis is positive feedback. Yours is negative feedback.
since the Vsense tends to decrease when it approaches fully charge condition, it should be connected to the +feedback and the hysterysis is connected to it? | ||
| Like this: EDIT: Current sensing resistor was in the wrong spot.
__________________ Uncle $crooge Last edited by audioguru; 11th October 2007 at 07:57 PM. | |
| question: mr.AG, does the Vref is set at the -feedback through R1 and R2? i'm just confused because i'm trying to compare this schematic to the attached one, why did you add another resistor at the +feedback, is it to divide the Vdrop from the current sense resistor? where is the Rh now on the circuit? | |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 1 | 4th October 2008 01:26 AM |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 06:17 PM |
| Battery charger help... | dieselmo34 | Electronic Projects Design/Ideas/Reviews | 14 | 18th December 2006 06:30 PM |
| Cheapo battery charger auto shutoff? | Iceman_Chris | General Electronics Chat | 3 | 21st November 2006 07:01 PM |
| Battery charger for mobile phone Motorola | 2PAC Mafia | General Electronics Chat | 0 | 4th October 2005 04:20 PM |
