Old 3rd October 2007, 03:59 PM   (permalink)
Originally Posted by ericgibbs
Some obvious changes I would suggest.
There maybe others.
Whats the Vref at the junction of 1K/470R, inp to Comp supposed to be?
the Vref should be 2.1V ( 2 x 2.1V = 4.2V )my apologies on the wrong values of resistors, because i did the schematic quickly... on the actual circuit, the ratio of resistors on +V of comparator is 1k/270 ohms, and the Voltage of the power supply is variable, on the circuit, we've came up with a 9.7V making the vref=2.06V (4.12V)
if you don't mind sir, what is the reason why should an 8mA be chosen to flow on the LED?(on our circuit, 9.7 / 2k = 4.85V.... 4.85V/1k = 4.83mA, which drives the LED and the NPN transistor)
on the hysteysis side, my friend suggest me to add a series diode(1n4148) after the RH, for one direction flow of current.is it correct?
what capacitive value should we use in parallel to the power supply on your edited schematic?what is the purpose of that sir?
hardcore misery is offline   Reply With Quote
Old 3rd October 2007, 04:51 PM   (permalink)
That was just a calculation.
A diode is not required, choose a Rh value that gives about 0.3V of hystersis.
I would suggest a 0.1uF and a 47uF in parallel, its decoupling, you dont want 'spikes' when the relay switches getting back into the comparator inputs.
Does that answer you questions?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now   Reply With Quote
Old 3rd October 2007, 10:44 PM   (permalink)
i had a different understanding on the concept of Hysterysis, based on what my friend told me, and you can give me sir some clarification about this...
if the resistor ratio is 1k / 270, and the input voltage is 9,7V, the Vref will be 2.06
if i will add an Rh equivalent to 2k ohms, the Vref will change AFTER the comparator turns OFF, which is equal to 1.86V (3.73V)
so if theres an hysterysis, the RH would only parallel to 270 ohms if the comparator shuts down, but in ON state of the comparator, only 1k and 270 ohms are used by the comparator..
i think what you mean by 0.3V hysteryssis is 2.1V (4.2V) - .3V is equal to 1.8V (3.6V) is this it? i'll report back soon, after we tried those suggestions of yours..
so is it the voltage spikes which is the culprit of our problem?
godbless and thank you sir.
Old 4th October 2007, 08:28 AM   (permalink)
Look at this drawing.
It should give you an idea what the hysteresis is doing.
Remember to calculate the Vref for a almost 'discharged' battery and the hysteresis to ensure a fully charged battery before charger shut off.
Is this clear?
Eric
PIC tutorials:
Old 4th October 2007, 02:27 PM   (permalink)
can't understand it fully (on the Vref=1.5V, this should be 2.1V?)
ok sir, we tried all your suggestions ( shunting a 47uF and 0.1uF capacitor across the supply voltage for RELAY and COMPARATOR, and shunting a Diode across Relay, and finaly, putting a 2.2kohms as hysterysis to the circuit)
we did some measurements on the circuit.
1. Power supply voltage for Relay and comparator ( so as the voltage input for Vref ) is equal to 9.484V and the Vref is equal to 2.033V ( ideally it should be 2.1V )
2. The charging voltage is 4.02V ( 2.01V as a result from 1k/1k ratio for -V of the comparator )
as i've stated on the previous post(s), at no load condition
( if the Charging voltage is 4.2V while the Vref is equal or less than the charging voltage(2.1V), the Relay switches on/off rapidly )
after putting those capacitors and diode as you've suggested on our circuit, the problem didn't removed.....
3. We observed the effects of adding hysterysis on the circuit.
at the +V of the comparator, the ratio of resistors are 1k / 270 ohms.. the supply voltage is 9.484V and it gives a Vref of 2.033V (without RH
but when the 2.2k was connected between the output and 1k/270, the Vref increased from 2.033V to 2.33V and when the comparator is off, the decreased from 2.33V to 1.895V
i don't know the computation for the Vref at ON state of the comparator, but on the OFF state of the comparator, the 2.2k was first paralleled to 270 (which is equal to 240.49ohms) and the ratio was 1k/240.49 then the Vref becomes 1.84, ** the resistors has tolerances, we didn't measure its actual resistances and 1.84 is close to 1.89V(actual Vref at OFF state)
so if the Vref increases due to 2.2k added resistor for hysteresis at ON state(2.33V) therefore the voltage required to turn off the comparator is greater than 2.33V?(4.66V, which should be 4.2V)
so this is another problem? the Vref should not be changed whether there is a hysteresis on the circuit(except for the Vref at OFF state of the comparator)
ok we used the circuit with added components as you've suggested, with a Vref of 2.33V, we tried to increase the charging voltage until it exceeds the Vref, AGAIN the Relay switches back and forth, rapidly, hence there's still a problem.
hope that all i've mentioned here is clear to you sir...
will for the reply... thanks and godbless..
Old 5th October 2007, 07:12 AM   (permalink)
I will study your last post and reply later.
Do you understand the diagram?
EDIT: Adding revised drawing.
I would suggest that you add a variable resistor in the junction of R3/4, this will give you some control while testing.
Look at this drawing, hope it explains OK.
Eric
PIC tutorials:
Old 5th October 2007, 02:59 PM   (permalink)
i had a wrong understanding about hysterysis, on our actual circuit.
we used 1k/270 ratio of resistors for the +feedback, and to configure the Vref to 2.1V... i was wondering why the Vref increases as the RH is added on the circuit... i realized that, we should include the RH to configure the ratio of resistors for Vref... i'll reply soon as after we revised our circuit.
thank you and godbless sir.
Old 7th October 2007, 06:24 AM   (permalink)
i'm having a hard time on setting the Vref(ON state) to 2.05V and Vref(OFF state)=3.6V
Old 7th October 2007, 06:54 AM   (permalink)
WHY are you trying to set the Vref at these voltages?
Look at the drawing I posted explaining the Vref and hysteresis.
Are you using a variable resistor, to set the Vb/2 or Vref as I have suggested?
Eric
PIC tutorials:
Old 7th October 2007, 07:13 AM   (permalink)
oops, it's a typoerror it should be
Vref(ON state) to 2.05V and Vref(OFF state)=1.8V
quick question sir, how can we properly discharge a li-ion battery? our problem is we need to discharge the batteries at approx 2.8V or lower than 3.7V.. if we can't achieve that, we have a problem on the Vref at OFF state(1.5V as you've suggested, or 1.8V)
i haven't tried those potentiometer on vb/2, i'm trying to get fixed values of resistors.. thanks sir
Old 7th October 2007, 07:23 AM   (permalink)
sir i think theres no problem on the ratio of resistors for vb/2, (1k/1k) the problem is on setting the Vref of ON/OFF states with the correct values of resistors
Old 7th October 2007, 07:36 AM   (permalink)
hi, hcm,
Tell me the type of opa/comparator you are using?
The quickest solution is going to be if I make a working version of the project,
so that I can tell you the resistor values.
Is the power supply still at +10Vdc?
Is the charger voltage still set for +4.2V?
EDIT: also give me details of the battery type, voltage, AHr,,,etc.
Eric
PIC tutorials:
Old 7th October 2007, 08:01 AM   (permalink)
hi, hcm,
thats great sir!!! we are 6 members on a group, and i'm the only one who works for our prototype..
we are using LM339 as a comparator, our supply is variable, but on my calculations we use 9.7V as a supply, and 4.2V as the charger voltage.
i think i got the correct resistors to be used.
R1=1k
R2=270
Rh=2200
RL=100k (r5 on the given schematic on previous post, is it ok to use this? previously 1k)
i got a vref(on state)=2.078V and a vref(off state)=1.8907V ( so we can charge batteries with voltage lower than 3.7V or 3.8V )
btw sir, how can we safely discharge li-ion batteries? on our sample batteries we can only got 3.7V.
quick question, our charging voltage is 4.2V and the limitting resistor is 10ohms, and we charge at least 3.7V, the charging current is only 50mAh, is this ok? or is it advisable to charge batteries with constant current? at least 300mah?
EDIT: Original Nokia Li-ion Battery BLC-2
950 mAh LI-ION / 3.6V
Weight: 108g
Talk time: 2h 40 min - 4 h 45 min
Standby time: 55 - 260 h
Variation in operation times will occur depending on SIM card, network settings and usage. Talk times is increased by up to 30% if Half Rate is active, and reduced by 5% if Enhanced Full Rate is active
Picture for reference only
Compatability:
3310/3330, 3410, 3510/3510i, 5510, 6650, 6800, 6810
Old 7th October 2007, 08:38 AM   (permalink)
R1=1k
R2=270
Rh=2200;;; This is lower than I would expect
Never try to discharge this type of battery to less than 2.8V, you could damage the battery.
Use a 10R 3Watt resistor as a discharge load.. DONT go less than 2.8V
The manufacturers claim that this type of battery, for a phone, can be charged a the 1C rate, but 0.9C is recommended.
EDIT: a 300mA charge current is about the 0.3C rate for this battery.
I'll build a prototype of your circuit, give me 24hrs.
Eric
PIC tutorials:
Old 7th October 2007, 08:42 AM   (permalink)
ok sir, that would be nice... so i can verify the status of our prototype (mainly the status at NO LOAD condition, which the the charging voltage is 4.2V and the Vref is lower than 4.2V (2.1V or 2.05V)
Lead Acid battery charger manojp01 Electronic Projects Design/Ideas/Reviews 5 29th January 2008 05:16 PM
Battery charger help... dieselmo34 Electronic Projects Design/Ideas/Reviews 14 18th December 2006 05:30 PM
Cheapo battery charger auto shutoff? Iceman_Chris General Electronics Chat 3 21st November 2006 06:01 PM
Battery charger for mobile phone Motorola 2PAC Mafia General Electronics Chat 0 4th October 2005 03:19 PM
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 0 4th January 2005 09:35 PM
