The requirements keep coming, one at a time, every few days.....
I gather you want mains shutoff when the battery is charged. To shut off the mains, you can detect the current consumed by the charger. When it falls below a set threshold, you can cut off the mains (presumably to avoid wasting the standby current?) |
sorry for that sir i'll be back soon, if my group wants to pursue with this project... so how can we do your idea sir? |
2) Monitor battery current and voltage during some charge cycles 3) Analyse that data using your brain(s) 4) Translate your idea(s) into an electronic drawning 5) Submit it to this forum Then, and only then advice will follow... ... |
folks...
Our group decided to use voltage comparators, one of my friend advised me to use an LM2901 quad comparator... but my problem is i can't understand how will i work on this component... based from this site: http://home.cogeco.ca/~rpaisley4/Comparators.html where can i put the 3V to 4V supply of the charger to the comparator? how can the comparator measure the voltage of a charging battery to know when to shut-off? can someone explain to me the basic concept for this comparator? or any can give some sample circuits? Requirements: >Supply Voltage for the cellphone battery is 3.7V >the Load Current of the supply must be 1A or greater to accommodate 3 or more cellphones to charge. here is the features of LM2901, let me know if it fits the requirements of the battery charger... Features • Single or Dual Supply Operation • Wide Range of Supply Voltage LM2901,LM339/LM339A,LM239/LM239A: 2 ~ 36V (or ±1 ~ ±18V) LM3302: 2 ~ 28V (or ±1 ~ ±14V) • Low Supply Current Drain 800μA Typ. • Open Collector Outputs for Wired and Connectors • Low Input Bias Current 25nA Typ. • Low Input Offset Current ±2.3nA Typ. • Low Input Offset Voltage ±1.4mV Typ. • Input Common Mode Voltage Range Includes Ground. • Low Output Saturation Voltage • Output Compatible With TTL, DTL and MOS Logic |
I didn't think you could find another major change to throw at us, but suddenly you've decided to charge three or more batteries (phones?) at a time. I don't think that anyone could have guessed that.
Now you're charging cellphones instead of standalone batteries? That's good, actually, because cellphones usually have a complete battery charger, well matched to their own battery. (The "charger" for cellphones is usually just a semi-regulated supply at around 120% to 150% of the battery voltage.) But if you do it this way, you only need a simple power source. My cellphone (with a 3.7V 900mAH battery) uses a 4.8V 0.9A power supply. The power source doesn't need to be switched off; the phone knows and does everything. One amp for three or more phones? My phone uses a 0.9A supply. |
yes sir, this is our main design project... just a few questions sir, to be able to supply 3 cellphone batteries with 3.7V/900mAH, do we need a 3A ac-dc transformer? as for the output voltage, we can only choose a value, greater than or equal to 3.7V, to accommodate 3 cellphone batteries? |
He wants to stop the charger from consuming standby power once the phone is charged he trying to make a "greenie product". Mmmm nice idea now to steal it ! |
[quote]just a few questions sir, to be able to supply 3 cellphone batteries with
3.7V/900mAH, do we need a 3A ac-dc transformer?[/QUOTE sir how about this idea? is this ok? |
comparator is the simplest solution...a more complicated solution is using a uC and ADC, it controls the current at different stage of the charging.
Mike |
^^ yes sir, and we will be working on that...
up for this
Supposedly, the Vref of the Voltage comparator is 4.2V ( voltage of a fully charged cellphone battery )
The rule of the comparator is to TURN ON when the –V is lower than the Vref (+V) And TURNS OFF when the –V reached the voltage of the Vref… On the circuit provided, the –V of the comparator is tapped at the +V of the cellphone battery (this is intended to monitor the battery voltage) The LED before the transistor (C828/npn was used) indicates the status of the comparator. Our main problem is this… at NO LOAD condition, the relay tends to turn ON/OFF at rapid motion(repeating process,on/off/on/off/on/off…..) I’ve understand this because, at no load, the comparator senses the charging voltage instead of the battery voltage which turns OFF the relay (charger voltage is 4.2V and Vref is also 4.2V which turns OFF the comparator). So if the relay is OFF, the comparator senses a ZERO voltage since there is no load… BUT When we’ve placed a cellphone battery which has 3.8V, again, the relay turns ON/OFF at rapid motion.. this is not expected, because If theres a 3.8V battery load, the comparator will sense a lower voltage than 4.2V Vref, which turns ON the comparator, but why does the relay turns OFF? We also tried to use a variable DC supply as a BATTERY TO BE CHARGE.. we’ve set its voltage to approx 3V, again the relay behaves as is.. What seems to be the problem? On our circuit, we did’nt put a Diode in parallel to the relay. And we did’nt set a hysteysis for the comparator… are there wrong connections on the circuit provided? Are there any wrong connections on grounding? We’ve also observed that when the ground of the battery charger is not connected at the ground of the Power supply of RELAYS and COMPARATORS, the ON/OFF switching of RELAY is very fast, but when we connect both grounds of the charger and the power supply, the ON/OFF motion of relay was decreased NOTE: when we pulled out the relay, the comparator behaves as what we have expected. i hope that all i've said is clear... thank you and godbless to all. |
Some obvious changes I would suggest. There maybe others. Whats the Vref at the junction of 1K/470R, inp to Comp supposed to be?
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:21 AM. |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 05:16 PM |
| Battery charger help... | dieselmo34 | Electronic Projects Design/Ideas/Reviews | 14 | 18th December 2006 05:30 PM |
| Cheapo battery charger auto shutoff? | Iceman_Chris | General Electronics Chat | 3 | 21st November 2006 06:01 PM |
| Battery charger for mobile phone Motorola | 2PAC Mafia | General Electronics Chat | 0 | 4th October 2005 03:19 PM |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 0 | 4th January 2005 09:35 PM |
