+ Reply to Thread
Results 1 to 6 of 6
Thread: Need HELP For PROJECT
  1. #1
    chrisliew Newbie
    Join Date
    Jun 2007
    Posts
    4
    Default Need HELP For PROJECT
    hi all, I am new in town. currently I was doing a project that using pic16f873a micro controller to connect to the computer. but i am facing problem with the connection on the serial cable, so as the program that link to the micro controller. Can any one recommend me a way for the connection on the serial cable by using MAX485 or RS232?
    Thanks for the comment.
    Best regard,
    chris liew
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Check my PIC tutorials, they use a MAX232.
  3. #3
    chrisliew Newbie
    Join Date
    Jun 2007
    Posts
    4
    thanks for the advise on the RS 232 board, but a having problem with the 20MHz crystal as i only has 4MHz crystal. will it be ok as i use 4 MHz crystal with 15pF capacitors?
  4. #4
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Quote Originally Posted by chrisliew
    Yes, 4MHz is fine, but bear in mind you need to alter any timings.
  5. #5
    chrisliew Newbie
    Join Date
    Jun 2007
    Posts
    4
    Nigel, can i know how much V the capacitors u are using for the tutorial circuit board? i got 2 kind. one is 25V and the other is 50V. will it be ok?
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,794
    Either would be fine - as long as they are higher than the highest voltage used (9V in this case).
+ Reply to Thread
Tags for this Thread
