money is a big issue here. i have to build twenty of these. plus i already bought the transformers
Don't the place you bought them from accept returns?
Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer.
Gaston. Like this:
Oh, I just thought that since most transformer primaries and outer secondary wires are not colour coded for proper phasing, that Gaston should measure the total secondary voltage once the circuit is built, and that it is ~48VAC. The circuit will work either way, it's just that wired the wrong way, the rectifiers will put out 60HZ DC instead of 120HZ. (or 50 instead of 100 in UK). Filtering is easier the higher the freq.
