Old 3rd July 2007, 11:53 PM   (permalink)
Default need help of this circuit part
I need help here urgently. Does the relay coil especially the connected junction are shorted between the Green Led and the resistor?
Example the pin 10, is it connected together with the coil, resistor and the COMMON pin?
xiaobai00 is offline   Reply With Quote
Old 4th July 2007, 01:47 AM   (permalink)
I'm not sure what you're asking, but I can make the following comments which might help:
1. The vertical dashed line that is to the right of pins 12 and 11 is meant to indicate that the schematic for those pins have been omitted for brevity. Pin 12 controls appliance #5 and pin 11 controls appliance #6 with the same DPDT relay and indicator LED circuit that are shown for pins 10 and 13.
2. The pins 10-13 are not connected to the vertical wire that runs just to the right of the "003" chip because there is no heavy dot where they cross. The "N/O" lead of the left pole of each relay is connected to this wire.
pc88 is offline   Reply With Quote
Old 4th July 2007, 01:58 AM   (permalink)
Yes, pin 10 is connected to the coil, resistor and the common pin, and not to the normally open pin at the bottom.
Superman returns..
bananasiong is online now   Reply With Quote
Old 4th July 2007, 01:50 PM   (permalink)
Beg to differ about the dashed vertical line above the RL7 coil. It indicates that the pair of contacts the vertical dashed line leads to and the other set of contacts to the right led to by the horizontal dashed line are both controlled by the RL7 coil, making it a DPDT relay.
Pins 11 & 12 are not connected in this application. The hollow dots probably indicate a connector to an external wire.
j.p.bill is offline   Reply With Quote
Old 4th July 2007, 02:25 PM   (permalink)
That's possible, but aren't the DPDT relays indicated by the horizontal dashed lines? You might be right about pins 11 and 12 - probably need to see more of the schematic to be certain about it.
Old 5th July 2007, 11:06 AM   (permalink)
I want the answer is this, the rest are not!! Please read the example carefully.
Old 5th July 2007, 04:50 PM   (permalink)
A simple "thank you" would be sufficient.
Power-On delay circuit tzitzikas General Electronics Chat 15 7th June 2007 07:48 PM
Need help about a 7805 regulator circuit ! Zarkabul Electronic Projects Design/Ideas/Reviews 26 13th June 2005 06:07 PM
start/stop watch circuit bd13 Electronic Projects Design/Ideas/Reviews 2 21st March 2004 03:06 AM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 12:30 AM
On-time delay circuit using LM555 mozikluv Electronic Projects Design/Ideas/Reviews 9 24th October 2003 01:44 AM
