Old 30th June 2007, 10:15 AM   #1
Default Help PT100 sensor
Hello,
I want to get temperature readings with pt100 sensor, does any one have a circuit to connect it to pic16f877, thanks in advance
Algerian is offline
Old 30th June 2007, 03:58 PM   #2
If that is a platinum RTD, you will need to send a currrent through it from a controlles source. Using a high-quality amplifier, amplify the voltage on the RTD up to a level compatible with the A to D converter in the PIC. After conversion, apply the values against a look-up table to linearize the signal.
One observation, though - an RTD is a very expensive and precise measurement device. Reading it with an 8 or 10 bit A to D is a bit like measuring dimensions in ells and spans. The units are just too coarse to give good results.
j.p.bill is offline
Old 30th June 2007, 04:14 PM   #3
Thank you very much for your reply, but please, if you have a reference of the high quality amplifier, or if you have the circuit with refernces and values will be very helpfull. Thanks again.
Algerian is offline
Old 30th June 2007, 08:07 PM   #4
If you are in a hurry, just buy one of these:
http://www.omega.com/ppt/pptsc.asp?r...94A&Nav=temn03
If you want to build from scratch, Maxim has some chips specific to this application:
http://www.maxim-ic.com/products/sen...rmocouples.cfm
and here is a useful application note with IC references:
http://pdfserv.maxim-ic.com/en/an/AN3450.pdf
RadioRon
RadioRon is online now
pt100, sensor
Help with PIR Sensor garyi Electronic Projects Design/Ideas/Reviews 7 1st February 2007 09:44 PM
submerging a pressure sensor under water? AndyWatson Electronic Projects Design/Ideas/Reviews 14 26th October 2006 10:38 AM
temperature sensor calibration dukebound85 Micro Controllers 11 21st November 2005 11:28 PM
RPM/Speed Sensor Calibration Scotsman General Electronics Chat 1 20th May 2004 12:07 AM
Need help identifying sensor / signal on motorcycle. Phoenix General Electronics Chat 3 7th May 2003 09:32 PM
