Old 21st June 2007, 05:59 PM   (permalink)
Question Calculating Time
Hi guys
How do i calculate time for a circuit or device from its Current?
Example:
If a 10mA LED connect to a 6V 4.5Ah battery with a 1K series resistor what is the maximam time of glowing LED ?
E2K is offline
Old 21st June 2007, 06:07 PM   (permalink)
Originally Posted by E2K
Hi guys
Example:
If you connect a standard LED, which has a forward voltage drop of 1.5V, then you will have 6-1.5= 4.5v across the 1K0.
So the current thru the 1K0 and LED will be 4.5/1000= 4.5mA..
To calculate the endurance of a fully charged 4.5Ah battery, in good condition, you divide the 4.5/.0045 =1000 hours.
This is an approximate calcultation as the current is so low, also the LED will continue to glow when the battery reaches it recommended discharged voltage of about 5.4V. The LED should be disconnected when the battery voltage fall to 5.4V for a lead acid battery.
EDITED:
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 21st June 2007, 06:11 PM   (permalink)
same formula can use for other circuits like a timer,flasher or others?
E2K is offline
Old 21st June 2007, 06:19 PM   (permalink)
Thats correct.
Its important to know the voltage drop across the LED, look at the LED specsheet, then subtract the LED voltage from the battery voltage.
Some of the higher powered LED have voltage drops in the order of 2 to 3Volts or more.
Does that help?
Eric
PIC tutorials:
Old 21st June 2007, 07:01 PM   (permalink)
I don't know of an LED with a forward voltage drop of less than 1.5V. See http://www.oksolar.com/led/led_color_chart.htm
Ron
Roff is offline
Old 21st June 2007, 07:16 PM   (permalink)
hi Ron,
Of course you right!.
Calculation was based in error on bog standard diode!.
I'll edit accordingly.
Many thanks
T'is done!
Eric
PIC tutorials:
MOSFET rise time? p1120 Electronic Projects Design/Ideas/Reviews 3 31st August 2006 09:14 PM
What BJT specification do I need to look at for switching time? FusionITR General Electronics Chat 3 9th July 2006 10:46 PM
Enquiry For Discrete Time Convolution & continuous time shermaine General Electronics Chat 3 4th August 2004 09:25 PM
sensor activated time measurement rajravi Electronic Projects Design/Ideas/Reviews 1 29th January 2004 02:01 AM
