| I've been trying unsuccessfully to build a 2w headphone amp from an NTE990/LM377. It is horrendously noisy, so I'm about ready to throw in the towel on this chip. I've had success with an LM386, but it doesn't put out enough power. Can anyone suggest a good 1-2 watt per channel audio amplifier with a schematic? The NTE was good because I didn't have to run it hot to get good amplification at the headphones (didn't run at the full 2w). Space and efficiency are big factors, it will be running from batteries and carried on a person. Thanks. Last edited by Ratch; 21st June 2007 at 05:30 AM. | |
| Have you looked at the LM675 or the ST Micro L165 power op-amp? Bob | |
| | (permalink) | ||
Did you refer to the datasheet of LM386 it shows how to control the gain by adjusting the Resistor & cap between 1 & 8 pins. Also there are some additional design circuits as well in that. Quote:
There are plenty single chip IC’s for your requirements but most are 6V, 8V onwards ones. Ex: KA2206, LA4140, TDA 2002 etc…. Circuits are in the data sheets. Here is another portable Amp with Discrete components. http://www.redcircuits.com/Page31.htm | |||
1) This Will Considerably Reduce that Noise. 2) It will PROTECT THE HEAD PHONES. ** I Have YET to See a 2 Watt pair of Head phones. Most Head phones are Less than .3 Watts. And Doing this will probably make that LM377 Amp to be suitable for Listening to. (Not that I would use that particular IC.)
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | ||
| I see the reason to include series resistors but what about the damping factor? With a 470
But Usually I Use a 150 Ohm, 1/4 or 1/2 watt resistor. Every commerical amp I have seen, uses a series resistor for the headphones.
It's pretty well the universal way to feed headphones. | ||
| That explains why headphones often sound ringy.
As Far as the Damping Factor goes, It also doesn't change that. As long as the Load has a Much higher Impedance than the Amp, everything is fine. Which is truly the case when using a resistor in series with the headphones. Besides, Since headphones are Directly against your ears, All frequencys are Much Greater equil to the origional sound quality with No Added Resonances or echo. That is Assuming the headphones have a Good Response to start with. Check it Out with a Dual Trace Scope, one side to a headphone and the other side to a Non Inductive Dummy Load. ** This Eliminates all ROOM Acoustics which can REALLY Modify the sound.
| Need advice about Audio Amp | folia | General Electronics Chat | 7 | 28th January 2007 06:39 PM |
