Old 19th June 2007, 02:10 PM   (permalink)
Default laser distance meter
I want to make a linear laser distance meter up to six metre
help pls....
salihcakmak@gmail.com is offline
Old 19th June 2007, 02:16 PM   (permalink)
help pls....
Buy one! - you're not going to make one.
Old 19th June 2007, 03:11 PM   (permalink)
I'll bet they are not available in his geographic location. Maybe you could buy one and send it to the dear soul.
Papabravo is offline
Old 19th June 2007, 03:18 PM   (permalink)
How would we know?, he's not filled his location it!.
Old 19th June 2007, 03:21 PM   (permalink)
I think it's a better than even money bet.
Old 19th June 2007, 11:49 PM   (permalink)
help pls....
Hmmm... Interesting little project...
The speed of light is 299,792,458 metres per SECOND...
So if you want to range find over 6 metres, you'll have to have some pretty shit hot timing routines to measure the return trip for the laser pulse!
The round trip time for the laser pulse at 6 metres is around 4.002769142377824594906920573699e-8 seconds!!!
or 0.00000004002769142377824594906920573699 seconds...
Not sure a microcontroller will repond quick enough!
Maybe an ULTRASONIC range finder / radar would be a better project???
Shax.
A bus station is where a bus stops...
A train station is where a train stops...
On my desk I have a work station...
Nuff Sed!!!
Shax is online now
Old 20th June 2007, 07:16 AM   (permalink)
Hello!
In fact it's not that impossible to build one. For sure, trying to calculate the time of flight is nearly impossible... (at least it's impratical). The typical way is to do trigonometry: you send the laser with a small angle and you receive it on a CCD. The position of the spot gives you an angle that you compute to know the distance.
Search the web, there are some hacks with laser pointers and webcam. Sure it's not industrial grade but it can be enough for some projects.
JFDuval
jfduval --@-- aqra.ca
http://www.aqra.ca
JFDuval is online now
Old 20th June 2007, 07:35 AM   (permalink)
If you want to build a low power pulsed laser to measure from say 0.5mtr thru 10mtr you can do it this way.
At the instant the laser diode is pulsed, set a 74F series monostable, start a fast run down linear voltage ramp.
On receiving the laser echo, reset the TX M/S and start a slow [*100] ramp up to zero volts of the TX ramp down voltage.
From the instant the RX echo pulse is detected start a 15MHz counter and stop the counter when the ramp up reaches 0V.
In the counter chain you have a count proportional to double the distance measured.
By chosing the 15MHz xtal [ speed of light is 300,000,000/sec] the counter chain gives a transit time count of 100* the actual transit time.
If you require more details please ask.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 20th June 2007, 01:29 PM   (permalink)
Originally Posted by JFDuval
Hello!
So, using TRIG, what happens if the reflecting surface isn't at EXACTLY 90 degrees to the incoming beam? I'm sure that would cause some error in the result......
Shax.
Nuff Sed!!!
Shax is online now
Old 20th June 2007, 01:33 PM   (permalink)
Hello!
I have the same question that you. I didn't investigated far enough to find an answer.
For sure this solution is viable, it's what is used in many commercial rangefinders. I just don't know how they deal with that angle.
JFDuval
http://www.aqra.ca
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 03:44 PM
ultrasonic distance meter maverick8888 Electronic Projects Design/Ideas/Reviews 3 11th September 2004 09:12 AM
min. distance in ultrasonic distance meter Maryam Micro Controllers 2 9th August 2004 11:18 AM
Distance meter with ultra sonic elnaz Micro Controllers 2 6th July 2004 10:54 AM
