| hello guys.. is there any easy way to get a +12/-12 square signal from a 12 volts battery ??? it should be able to handle about 0.5 A not more... | |
| the frequency should be 1 to 2 Hz | |
| Why? What exactly are you trying to do? If all you want to do is flash a lamp then you can buy special relays for that or you could use a 555 timer driving a transistor like the BC549.
| i need it to have an 2 outputs... in the first 0.5 seconds..the first output should be 12 volts and the other is zero... in the next 0.5 seconds the first should be zero and the other one is 12 volts....and as i said.. just 0.5 A | |
| what are you trying to make? As hero said, if it's just to flash some lamps, there is already circuits out there for that.
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
| hmm... it s for making a disk coupled on a dc motor rotate in one direction then in an other.. | |
| ok, well a simpler way would be to just switch the polarity of the motor, making it spin the opposite way. unfortunately i don't have any circuits in mind at the moment, so maybe someone else can help with this.
| You can get h-bridge ICs for that like the L298 or L293 for example. All you need to do is add an astable 555 timer oscillator running at 2Hz and you've done it.
| i ll try looking for the l298... and about the circuit that switch the polarity of the motor... that would br8 and so easy to use ... but me 2 i have no ideas about how to do it | |
| haha, i like that animation
| 10x guys for your help... but i think that the animation circuit can t run a 12 volts 0.5 A motor.. right ? | |
| could you use relays?
| Well the initial question bears no resemblance to the actual requirement, but to reverse the motor a simple DPDT relay driven from a 555 timer is really all that's required. | |
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 02:45 PM |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Anybody got information on line driving a c-sync signal? | FusionITR | General Electronics Chat | 8 | 15th April 2006 05:16 PM |
| PIC output signal not a nice square wave | ChrisBennet | Micro Controllers | 4 | 27th February 2004 12:51 AM |
| Yet another LED taillight controller...... | NickK | Electronic Projects Design/Ideas/Reviews | 1 | 31st March 2003 06:38 PM |
