Old 19th June 2007, 11:53 AM   (permalink)
ok guys... i think the l298 and the 555 timer could be an easy solution...!
but the problem is that this is the first time i work with a 555 timer... how can i get the 2 hz frequency ??? and what is the most common 555 timer IC ??
and about the l298 what are the EnA and the EnB pins for ??
Inferno is offline
Old 19th June 2007, 11:55 AM   (permalink)
i think it depends on the resistance between two of the pins?
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 19th June 2007, 12:44 PM   (permalink)
hmmmm thinking abt the dpdt relays and 555 timer...
the 555 timer should work on 5 volts or it could work on 12 volts ??
anyway ... what would u recommend for a dpdt relay that work with the 555 timer and 12 volts dc motor ?
Inferno is offline
Old 19th June 2007, 01:12 PM   (permalink)
and could a relay handle switching 2 times every second.... ??? ( 2 hz frequency )
Inferno is offline
Old 19th June 2007, 01:13 PM   (permalink)
Yes it can - but can the motor handle it?, and why do you want to do this anyway?.
Nigel Goodwin is online now
Old 19th June 2007, 01:24 PM   (permalink)
i m trying another oscillating motor circuit..like for beam bot application...
but i was thinking... how should i connect the motor to the relay so it would be forward and backward..i know how to do it to make it on an off....and what relay shell i use ?
Inferno is offline
Old 19th June 2007, 01:56 PM   (permalink)
Originally Posted by Nigel Goodwin
Well the initial question bears no resemblance to the actual requirement, but to reverse the motor a simple DPDT relay driven from a 555 timer is really all that's required.
Thinking the same thing, he is not asking for speed control just fwd/rev and it would all run off +12V, also a lot cheaper!.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 19th June 2007, 02:05 PM   (permalink)
could anyone help me abt the dpdt relay... i really don t know a lot about it and can t find any blockdiagram for it on the net...
Inferno is offline
Old 19th June 2007, 02:14 PM   (permalink)
You might perhaps know it as 'two pole changeover'?.
Old 19th June 2007, 02:31 PM   (permalink)
This should give you the basics, calculate the 555 timer components yourself, get the 555 datasheet from www.datasheetarchive.com
Does this help?
The pic file is being rejected?, I'll be back
Hi again!
Had to redraw, excuse quality.
Before you go any further, make sure your motor will reverse, when you reverse the battery connections, some motors may not!
Eric
PIC tutorials:
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
Anybody got information on line driving a c-sync signal? FusionITR General Electronics Chat 8 15th April 2006 05:16 PM
PIC output signal not a nice square wave ChrisBennet Micro Controllers 4 27th February 2004 12:51 AM
Yet another LED taillight controller...... NickK Electronic Projects Design/Ideas/Reviews 1 31st March 2003 06:38 PM
