Old 19th June 2007, 01:34 AM   (permalink)
Default Parallel port driving ADC problems..
Hi All,
I posted a while back on the use of the PC parallel port to drive a DAC and ADC as an interface to a variety of sensors/PWM's. I breadboarded a circuit and have written the software in VB6. The DAC chip performed perfectly first time out ( not what I was expecting! ), I can specify a voltage by moving a slider in the software and instantly get a corresponding voltage output. The ADC uses the same SPI interface and is driven in a similar way to the DAC. Although I can get the ADC to respond and return a voltage, all I get back are random spurious readings even when trying to read the internal test reference voltage. I've been through the datasheet with a fine toothcomb but cannot find anything that could be causing the problem, at least from an electronics perspective. I've checked the software thoroughly, slowing the timings right down to tenths of a second, making sure that everything is synchronised in terms of input clock pulses and data and the converted output data, but it's got me stumped. If anyone has experience of the TLC2543 ADC or even of driving this IC through the parallel port I'd be greatful for any input! I've attached a schematic showing the breadboard setup.
Thanks!
saiello is offline
Old 20th June 2007, 08:55 PM   (permalink)
Perhaps you should try to make some simple software to start with. You know; "Barebones". When i make software (highend), i like to make simple little bits of code just to get things to work, and then reprogram it to work in the "big picture". If you are sure that your code is right, then i would also try some different circuits. Maybe some LEDs on the output lines of the ADC? That way you can see what is happening?
I have never used an ADC or DAC before, so maybe this is dumb advice, but someone somewhere could use it.
Good luck. If you get a chance, maybe you could post some source?
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 20th June 2007, 09:36 PM   (permalink)
Hi!
Thanks for the reply! The DAC I'm using ( TLC5628 ) and the software worked great first time out. The ADC (TLC2543) uses similar VB code and the structure of the sequence of instructions sent is also very similar. I'll re-write the code to explicitly step through the 36 byte instruction sequence byte by byte as it it sent to the ADC so I can check the lines with a voltmeter. I've checked some application notes on the Texas Instruments website specifically for the 2543 and the last example shows use of a microcontroller directly interfaced with the 2543 and using purely software to drive the SPI interface ( i.e. Chip Select, I/O clock, data in and data out lines ), so logically no reason why a PC couldn't do the same. Once I write the test code I'll post it so that you ( or anyone else that's interested! ), can see the exact information the ADC is getting and tie this in with the information contained in the datasheet.
Thanks!
saiello is offline
Old 21st June 2007, 03:12 PM   (permalink)
I've written the 'bare-bones' code to drive the ADC. I've attached the code and also the datasheet for the TLC2543. Still no joy, I'm stumped..!
Cheers,
Salvatore.
saiello is offline
Old 21st June 2007, 03:47 PM   (permalink)
hi salvatore,
Looked thru your VB code fragment, unable to run it as its not complete.
Perhaps a simple question, are using Windows XP, if so you will require a *.dll
in your Windows/System directory. I use 'inpout32.dll'.
I have written a parallel port test program using VB5, if it would help let me know and I will post it.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 21st June 2007, 05:07 PM   (permalink)
I'm using XP Pro and the same inpout32.dll. I've amended the code ( attached ) to include the declarations for the input/output functions so it should now work as is. Incidentally, I had changed the DB25 pin assignments slightly to accomodate the test code and as such I attach the resulting revised schematic. I can drive the TLC5628 DAC in a similar fashion and it works sweet, it's the TLC2543 ADC that's giving me headaches.! I can certainly get results back from the ADC but they are totally spurious readings! I thought at first it might be an input/ouput synchronisation issue, but I've revisted the code many times and can't see any problem. I also suspected that I might not be driving the ADC according to the datasheet, but again can't find anything that suggests I'm doing something wrong. If you've got some software to test I'd certainly appreciate trying it out!
Thanks,
Salvatore.
saiello is offline
Old 21st June 2007, 05:59 PM   (permalink)
hi salvatore,
The *.zip includes the source code in VB5, also a *.exe file.
The purpose of the program is just to exercise the parallel port I/O.
I will re-try your code, I will have to simulate, in some way, the ADC ic.
If I get a result I will get back to you.
Eric
PIC tutorials:
Old 21st June 2007, 09:25 PM   (permalink)
Hi Eric,
Thanks for the code! I sent an instruction sequence to the ADC by toggling bit 1 ( DATA 1, Pin 3 ) for the CLK and monitored the output bit 6 ( STATUS 6, Pin 10 ). After running through a number of 12-bit instruction sequences and writing down the output results, I found I was still getting random results.
I'm going to have another hard look at the datasheet to see if I've missed something.
Thanks again,
Salvatore.
saiello is offline
Old 22nd June 2007, 08:22 AM   (permalink)
hi Salvatore,
Look at this, in your coding.
ADCResult(0) = Inp(STATUS) ' Read STATUS port and store MSB
'D9
ADCResult(2) = Inp(STATUS)
Out DATA, StringToBits("00000100")
Out DATA, StringToBits("00000110")
Is this statement supposed to be here??, you are changing the state of the MSB to the state of B9
I have inserted some dummy values into your ReadSubr and it gives the correct results. A problem occurs in D9 read block.
To test I changed ADCResult(0) to 64' Inp(STATUS)
and ADCResult(1 thru 11) to 32' Inp(STATUS), and deleted the *** line.
Thus gives a final result value of 2048, which is correct.
I expect you know that your code is not optimised and could be reduced in size and also faster.
Regards
Eric
PIC tutorials:
Old 22nd June 2007, 09:54 AM   (permalink)
Looking at the ADC setup routine in 'ReadVoltage', if I am reading page #14 of the datasheet correctly, the setup is addressing AIN3. You appear to be using AIN0 as a 2.5Vref test value?.
Page #14 also states its an 8 bit function select byte, you are adding, 4 padout bits?
On page #12 of the datasheet, 'Principles of Operation' it again states its an 8 bit control data stream.
On page #9 it states that the data I/O is simultaneous, you are addressing and reading sequentially?
You appreciate that unless I have a device to test with your program, I have to take all my information from the datasheet.
The way I read the datasheet, you are not controlling it in the way it describes.
Regards.
Eric
PIC tutorials:
Old 22nd June 2007, 03:49 PM   (permalink)
Hi Eric,
Thank you for your patience! You are right in pointing out the mistake in the code I posted. In actual fact the code itself does not contain this error, it was introduced after cutting and pasting the code into Notepad and making a few adjustments to pretty it up..! Sorry! To keep things as simple as possible, I have attached a shorter, clearer version of the code that uses AIN0 on which I have 2.5V. This equates to an actual instruction sequence of all 0's, so all I am effectively doing is sending CLK pulses to the ADC. On every call to ReadVoltage(), I have also added a bit of code to initialise the ADC according to the datasheet by taking CS temporarily HI and then LO again and then waiting a bit for the ADC to settle down.
In answer to your query about the 8-bit function select byte, the ADC allows 3 choices in terms of length of the instruction sent to it depending on the type of serial communications mechanism you are using, 8-bit, 12-bit( recommended as the ADC has a 12-bit resolution), and 16-bit ( see page #15 - Principles of Operation - data output length). The function select byte is 8 bits which in my case has to be padded to 12 bits. There is a timing diagram on page #9, figure 9 which is the control scenario I am trying to implement.
In answer to your other query about the ADC being simultaneous, yes it has been designed this way for fast operation. As you are sending an instruction, the result of the previous conversion is shifted out, so the desired result lags behind by one instruction sequence. In my code, I send the instruction twice, the first is the 'real' instruction, the second as a 'dummy' to get access to the result. Although not in the datasheet, the method I'm using is actually recommended in the manufacturers application notes if all you are interested in is 'one-shot' conversions. If you are trying to convert a fast continuously varying signal then the simultaneous method is obviously recommended for speed.
I've tested the attached code and am still getting spurious results as before. Not entirely sure where to go from here...
Thanks,
Salvatore.
saiello is offline
Old 22nd June 2007, 05:57 PM   (permalink)
When I was working with ATMega16's ADCs I faced a similar kind of problem. The output was very unstable. Later I found out that in the breadboard the voltage of the ground rail was 150mV. May be yours is the same problem.
rahat5810 is offline
Old 22nd June 2007, 06:25 PM   (permalink)
hi salvatore,
Try this code, add to the Form, 1 sec Timer and a Text1 box.
This works using the parallel port and a project board. The ADC is simulated.
Option Explicit
Dim DATA
Dim STATUS
Dim ADCValue As Single
Dim Ary(12) ' for precalculated power values
Private Sub Form_Load()
DATA = &H378 ' LPT1 port address
STATUS = &H379 'STATUS port address
MakeAry
End Sub
Private Sub MyRead()
Dim Rd, iADCValue, V As Integer
Dim t As Long
'this routine,selects ADC0, 12 bit data, msb 1st, binary, NOT using /CS as Page #9
'remember to allow for EOC time out
        For Rd = 0 To 11
        V = Inp(STATUS) And 64
        If V = 0 Then GoTo skip1
        iADCValue = iADCValue + Ary(Rd)
skip1:
        Out DATA, 0 'ck=lo, cs=lo, dta=lo
        Out DATA, 2 'ck=hi, cs=lo, dta=lo
        Next Rd
End Sub
Private Sub MakeAry()
Dim z As Integer
For z = 11 To 0 Step -1
Ary(z) = 2 ^ z
Next z
End Sub
Private Sub Timer1_Timer()
MyRead
Text1.SelText = "Decimal= " & ADCValue & "         Vadc= " & (ADCValue / 4095) * 5 & vbCrLf
End Sub
Read the comments.
I'll look thru your latest *.zip
Regards
Eric
PIC tutorials:
Old 23rd June 2007, 12:40 AM   (permalink)
Hi Eric,
Neat bit of code! I tried it and it does give me more stable results, either 0V or a value around 4.9V, but not the value of the input to AIN0 which is still 2.5V. I amended my own code to make it more streamline and I get the same results. What I did find interesting is that if I place any piece of code anywhere in the For..Next loop I start to get completely random results again! E.g.
For Rd = 0 To 11
' Add any code here.. e.g. Wait 0.001
skip1:
' ..or here.. e.g. DoEvents
' .. or here with this bit of code..
For n=0 to 100
Next
Next Rd
What's even more interesting is that if I reduce the extra loop to n=0 to 10 for example, I get back the more stable results as mentioned above...! This implies some sort of timing issue problem but I was under the impression that the ADC can be driven asychronously, as there is no mention in the datasheet of the need for any independent clock. I did come across this little snippet though, near the bottom of page #12 - Principles of Operation - Conversion Cycle:
"..The conversion cycle is transparent to the user, and it is controlled by an internal clock synchronized to I/O CLOCK..". How any internal clock can synchronise with an externally applied clock of indeterminate frequency I don't know.. Maybe it has no bearing on the problem... Hmmm..
Thanks again,
Salvatore.
saiello is offline
Old 23rd June 2007, 07:56 AM   (permalink)
hi Salvatore,
By inserting a DoEvents, which you should have in any long loop, Windows can 'insert' its other event any where in the loop.
If you have an oscilloscope to monitor the port output pins, you will see the output pulses are not 'equally' spaced in time, which in some external circuits can cause timing problems.
According the specsheet the ADC clk can be from 0 thru 4MHz, so I would not expect the timing problem you are getting.
Making an array with the bit weightings precalculated makes the sums and program easier/faster.
What you could do, is to load a picture box into the Form and place a preprepared 'graticule' image in the picbox and let the program draw the out and inp pulses to the picbox. This will give you an insight into what is happening. Of course its just for testing, like an oscilloscope.
I have use this method a number of times when trying to sort out port timing relationships.
Regards
Eric
PIC tutorials:
Parallel port control port: is it Write Only or Read/Write elexhobby Electronic Projects Design/Ideas/Reviews 6 23rd December 2008 11:18 AM
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 07:05 PM
I need: Parallel Port.. examples and applications.. sonaiko General Electronics Chat 8 28th October 2006 02:44 PM
PIC 2 PC: Parallel (Port) Read Electrix Micro Controllers 8 31st July 2005 05:24 PM
Multiple devices controlled at once on one parallel port Kerri Ann Electronic Projects Design/Ideas/Reviews 0 18th February 2005 11:52 AM
