| I need some help drawing library parts for Qtouch chips. The part I'm working with, the QT100 requires pads 5 to 7mm (or larger). so I went in library editor and drew a substantial circle, large enough to accommodate a 3mm led in the center with a few mm of clearance to the actual sensor ring question is, how do I tell eagle that it's a part which can be connected to, but doesn't need any gaps in the solder mask, since they will not be any components soldered down. right now, I just manually draw the circles on the layout, and use the wire command to connect them to the circuit, but that doesn't show up on the schematic, and the drc complains about it.
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
| Free sample chips! | mixos | General Electronics Chat | 29 | 25th October 2008 09:23 PM |
| Touch Sensitive Switch (Take 2) | MonkeyMera | Electronic Projects Design/Ideas/Reviews | 7 | 2nd October 2007 11:05 PM |
| Noise handling algorithm in 8 wire touch screen | hanhao | General Electronics Chat | 1 | 30th April 2007 12:11 PM |
| multiple touch switch problem | sstimuluss | Electronic Projects Design/Ideas/Reviews | 3 | 15th January 2007 03:03 AM |
| Gio Touch Lamp Replacement Circuit Help needed! | sbuc | General Electronics Chat | 0 | 15th November 2003 05:41 PM |
