hi everyone
could someone help me with this, i dont really know all that much about electronics but find them very interesting, i have a small 2 stroke engine it has a magneto, iwould like to get rid of the magneto and use a 6v battery and hall sensor arrangement, i have an understanding of it works but not sure exactly what to use. heres what i know (not much magnet on crank or flywheel hall sensor on crankcase resistor? not sure if i need a transistor ? battery coil i think this would work as a basic system (no advance) but im not sure how to wire it up or what types of the components to use. if this would work could someone show me how, also how difficult would one with auto advance be would it be possible to make a smaller coil also, smaller than the standard one i know this is alot of questions but i would appricate any help thanks |
thanks
but i already know about that site i have been searching the net for months trying to work this out. the whole idea is i dont want to spend lots of money on something that is made up from a handfull of cheap parts plus i like the satisfaction of making my own things. |
Then try this site. It can be built with or without the advance.
http://www.rcuniverse.com/forum/m_4344316/tm.htm John |
thats very interesting and probably answers my question about how hard it would be to have auto advance, but its way over complicated and the info incomplete.
i would really appriciate some one doing a sketch of what wire goes were on a basic system as described in my first post. its just for a little project i want to try so i dont want to get over complicated failing that could someone at least tell me wether a hall sensor could handle the supply voltage to the coil or would it need to switch a transistor. |
Electronic (pointless) ignition isn't terribly simple, I would suggest you either buy a commercial modification kit for your specific engine (if available) or leave it as it is!. You need a lot more than just a hall effect sensor.
(permalink) | ||
John |
a kit would be good but i cant find one, however the schematic is the kind of thing ive been looking for
thanks |
If you are in the USA, give C-H a call. They will sell you most of the components you need, in particular the step-up transformer and the ignition coil. I don't believe they have a kit, which would probably cost more than a completed unit anyway. You can build the step-up transformer (see the DIY site I gave in an earlier post). I would strongly recommend that you buy the ignition coil. John
| Electronic Ignition for bangers. | bitem2k | Electronic Projects Design/Ideas/Reviews | 5 | 16th May 2007 05:44 AM |
| Electronic ignition control system | royal1979 | Electronic Projects Design/Ideas/Reviews | 4 | 18th May 2006 12:30 PM |
| Need help building a transistor electronic ignition box. | grant31781 | Electronic Projects Design/Ideas/Reviews | 0 | 18th January 2006 02:10 PM |
| frequency-voltage don't work with electronic ignition. | Screech | General Electronics Chat | 7 | 16th March 2004 12:28 AM |
| Electronic Ignition | zambo | Electronic Projects Design/Ideas/Reviews | 5 | 22nd June 2003 12:09 AM |
