Old 15th June 2007, 03:53 PM   (permalink)
Default Solar Powered Charger
Hi. I am building a solar powered charger. I am using two MPT6-75 solar panels; output v=6v, i=50mA, connected in parallel, for higher current. I want the output voltage to be 5v. So at first I used a 5v voltage regulator. But the charger is not working. I found out that for the regulator to work I need at least 7.5v to work. So then I read about a step-up/down regulator, MAX710. And thinking about it, this seemed more like the thing I would need because the panels give varying voltages from 0 up to 8v. However, I do not know how to use the MAX710. I have been reading the PDF but am confused. Would this work to supply a steady flow of 5v and anywhere between 500 and 100mA? Also, can you explain how to use the MAX710; do I have to make a circuit board to mount this on?
Thanks for any help.
vinnie_c is offline
Old 15th June 2007, 04:00 PM   (permalink)
It's a charger - you don't need to voltage regulate it, and the tiny output of the panels probably isn't enough to overcharge batteries either.
Nigel Goodwin is online now
Old 15th June 2007, 08:46 PM   (permalink)
Lets see....
6V input at 50mA = 0.3W and 5V out at 100mA = 0.5W!
Well no, you wont be able to create energy from nothing.
How's about 5V output @ 48mA assuming 80% efficiency (not tough)
I know nothing of the MAX710 but first check your power calculations to see if it is physically possible.
Optikon is online now
Old 16th June 2007, 02:05 AM   (permalink)
The solar panels will produce 6V/50mA only at noon on June 21st on a very sunny day if the panels are pointing accurately at the sun. The output will be less in any other condition. It might take weeks to charge a battery.
audioguru is online now
Solar Powered Battery Charger tydude Electronic Projects Design/Ideas/Reviews 7 18th March 2007 11:32 AM
Solar powered lead acid battery charger plus Inverter Raj Lalvani Electronic Projects Design/Ideas/Reviews 4 13th March 2007 07:12 PM
Solar battery charger with moving panel Hanford Electronic Projects Design/Ideas/Reviews 6 8th October 2006 02:38 PM
Solar charger / Led lighting vwchico Electronic Projects Design/Ideas/Reviews 6 31st January 2006 06:56 AM
converting some solar powered garden lights cool-agent Electronic Projects Design/Ideas/Reviews 1 2nd April 2004 05:39 PM
