| I have to demonstrate simple infrared transmission/reception to learners. I can get hold of the tsop1736 receiver, but i am not sure how to use it. Do i need to use the carrier signal, 36 Khz ? Can i simply send a square wave with a 555 and an IR transmitter, or is it more complicated than that ? | |
| A simple carrier will make it's output go low - but it's not designed for operation with a simple carrier, and the AGC will tend to reduce the gain a lot. Best to use two 555's, one at 36KHz gated on and off by one at a couple of Hz - use an LED on the output of the TSOP, and you will see it flash from the IR. Add a second LED on the transmitter slow 555, and you can demonstrate the relationship between the two flashing LED's. | |
| Ah, thanks. So the carrier keeps it kind of alive ? I'm gonna experiment with it a bit. | |
| Please explain some more on the agc. | |
| The datasheet explains how the Automatic-Gain-Control (AGC) reduces the gain if there is DC IR from sunlight or continuous 36kHz IR pulses from fluorescent lamps with electronic ballasts. It explains that bursts of pulses are required to keep it at its most sensitive gain. It lists the recommended number of pulses in each burst and the amount of time for each pause between bursts.
| Universal Infrared Receiver using Microcontroller PIC12C508A | Darren | Micro Controllers | 3 | 16th December 2005 01:47 PM |
| Infrared receiver acting weird | Lac | General Electronics Chat | 16 | 10th August 2004 03:37 PM |
| Decoding Sony/RC5 Codes for Infrared Receiver | audion | Electronic Projects Design/Ideas/Reviews | 1 | 9th June 2004 06:51 AM |
| n00b needs advice: Infrared Emitter and Receiver | Shion Uzuki | General Electronics Chat | 2 | 3rd June 2003 07:27 AM |
| tv infrared receiver | rencecb | General Electronics Chat | 2 | 3rd January 2003 05:23 AM |
