Old 14th June 2007, 05:02 AM   (permalink)
Default RF design for remote strobe firing
I have a working design using a Linx keyfob transmitter and a Linx LR series
Receiver module with MS series decoder design module.
I use a tl106 SCR to fire the external flash units. Everything works fine except
the flash only syncs at 1/25th sec I need at lest 1/125 sec what can I do to achieve that. If necessary I am willing to go with a Pic to get the best
result if no inprovements can be made on the current design.
Thank You
Mike Lewis
Mike Lewis is offline   Reply With Quote
Old 14th June 2007, 05:31 AM   (permalink)
Sorry, but it's not too clear what you have, or what you are trying to accomplish, other than you want to cut the delay in half. You'll need to provide much greater detail if you want help refining this.
HarveyH42 is online now   Reply With Quote
Old 14th June 2007, 03:07 PM   (permalink)
To get a better understanding I have included my circuit diagrams.
This should give you a better idea.
Thank You
Mike Lewis
Old 14th June 2007, 03:37 PM   (permalink)
Default Coding delay.........
Thank You
Mike Lewis
The coding and decoding delay might be what is casing the problem. You need to do some investigation with an oscilloscope to find out how much it is.
Good Luck!
Rolf
Rolf is offline   Reply With Quote
Old 14th June 2007, 03:43 PM   (permalink)
Thank You
You are right the coding and decoding is eating up about 20ms
Is there a way around it?
Mike
Old 14th June 2007, 03:59 PM   (permalink)
Thank You
Mike
Use RF without coding. Like this: http://www.pbase.com/sinoline/rf_rem...ntrol_for_d7xx
Check for Private Message, upper right hand corner.
Rolf
Old 14th June 2007, 09:16 PM   (permalink)
Increase your baud rate. Right now you're using 9600; the chip set can go to 28,800 by connecting both baud signals to "1".
mneary is offline   Reply With Quote
Old 15th June 2007, 02:51 PM   (permalink)
Default Feedback Please ............
Well, did it take care of your delay problem?
Old 16th June 2007, 01:28 PM   (permalink)
It was a little difficult to make the changes, but when made It never
Worked. I am doing a little more research and may take a different
approach. I will have to order a few parts to make changes.
I will post the changes and results when made.
Mike
help understanding this hbridge design.... jaydag71 Electronic Projects Design/Ideas/Reviews 2 5th June 2007 10:37 PM
Accessing EEPROM Clayton Micro Controllers 15 23rd March 2007 03:00 AM
Texas Instruments New Design Center. chemelec General Electronics Chat 0 18th May 2006 10:33 PM
Analog design: Some things to remember Roff General Electronics Chat 18 8th November 2005 01:38 PM
anybody knows how to design a calculator??? eleanor Electronic Projects Design/Ideas/Reviews 4 12th August 2005 05:44 PM
