Old 14th June 2007, 04:34 AM   (permalink)
Default Fake cigarette using LED, need help
I am looking to design a fake cigarette out of an orange LED and a white bic pen. I am going to place the switch on the "filter" side of the cig so that when held, the cigarette lights.
However, if possible, I would like for the LED to slowly dim to full brightness when you press and hold the ON switch, much as how when you inhale a cigarette, the orange on the end gets brighter and brighter until reaching a maximum.
I have no idea how I would make a push-button switch gradually change the amount of power going to the LED. Perhaps instead of a switch, I should just use a very small pot? But that would make it a joint, not a cig
moeburn is offline
Old 14th June 2007, 05:43 AM   (permalink)
Considering the limited space, maybe a microcontroller to fade in/out the LED, pushbutton to trigger an interupt. What kind of batteries? Probably need two watch batteries, but don't they would last very long.
HarveyH42 is offline
Old 14th June 2007, 05:52 AM   (permalink)
To insert all these stuffs (Battery + circuit + LED + switch) even a Pipe Cigar’s space is not enough. You need a giant cigar to insert all these stuffs.
There are some automatic LED’s which fades automatically (the circuit is inbuilt inside the LED) only need power. But I’m not sure the orange colour is available.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 14th June 2007, 06:17 AM   (permalink)
I have batteries that fit inside the pen. The LED fits inside the pen. So does a simple pushbutton switch (SMT). If the circuit requires an IC, it would have to be SMT as well. I can fit all of those together inside the pen easily, and still have room.
The LED can be yellow, with a plastic orange filter on the end.
moeburn is offline
Old 14th June 2007, 06:32 AM   (permalink)
Tell the type of batteries? voltage?Is that coin batteries?
Can you mount a standard DIP IC?
Gayan
My Website
Old 14th June 2007, 08:26 AM   (permalink)
Try this and see whether it is working or not. Play with the capacitor value to get the RC time constant.
Superman returns..
bananasiong is offline
Old 14th June 2007, 08:55 AM   (permalink)
Maybe the LED will stay on all the time for the above schematic. How about this?
I don't have simulator in working place, I just use paint to draw.
Superman returns..
Old 14th June 2007, 09:18 AM   (permalink)
Look at russells thread "Why this simple oscillator/flasher doesn't work?"
and copy 'hero's' relaxation oscillator.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 14th June 2007, 10:19 AM   (permalink)
hi moeburn,
Have a look at this for your LED output.
http://www.etgtech.com/pdf/RAINBOWLED.pdf
Hi Gayan, Knowing you,, its a must have!
Eric
PIC tutorials:
Old 14th June 2007, 10:50 AM   (permalink)
Hi Eric the same LED has in my country cost 5Rs.RGB ones. But I saw one time a single colour is available (with fading effect).Its was a red colour one. I couldn’t buy that one, now need it very much.
The operation of the RGB LED is like this
R-G-B-RG-RB-RGB Repeat Continuously
R-OFF-G-OFF-B-RG-OFF-GB-OFF-RB-OFF-RGB-OFF sequence Repeating continuously
A single colour will be good for this project.
Gayan
My Website
Old 14th June 2007, 12:48 PM   (permalink)
Check these out:
http://www.goldmine-elec-products.co...?number=G15473
When I first saw them, I thought they looked cool but they were a higher pressure range than what I could use. Maybe something like that could be of some use for this project? Sorry, but I don't think electronic goldmine will deliver to where you are, but maybe you could have a friend send you one or look around where you live for one.
I think the idea of having a fake cigarette is neat, and using watch batteries is a great idea. If you needed more space for the controls though, could you maybe rig something up to the actor's wrist, like a fake watch with most of the circuitry and power supply, with some flesh-coloured leads to the LED in the cigarette? You could have the contacts open on the actor's fingers, so the power supply is connected when they pick up the cigarette.
Hank Fletcher is offline
Old 14th June 2007, 05:14 PM   (permalink)
If you need to make a filter, why not just use hot glue? Melt some, and mix in some carbon, or maybe even some chunks of graphite (pencil lead). I guess you could even try pepper, but that might be kinda weird... This way, when your LED fades in and out, parts will look darker than other parts, just like a real cig.
Too bad we couldn't get all smokers to use these things, that way they would STOP WITH THE SECOND-HAND SMOKE!!!!!!!!!!!!!!
There is no "I" in "team", unless Apple makes it... Then it would be iTeam.
Marks256 is offline
Old 14th June 2007, 05:18 PM   (permalink)
Only just over two weeks now till it's banned in the UK in all public enclosed spaces
So no smoking at work, in work vehicles, in pubs, in clubs, in restaurants, in offices, in public buildings - should be a LOT better!.
Nigel Goodwin is online now
Old 14th June 2007, 10:05 PM   (permalink)
Most yellow ("amber") LEDs (590nM) contain very little orange (610nM) so a filter might not accomplish much. An alternative is to use two LEDs; a red (640nM) that stays almost constant and a yellow that gets brighter when you puff.
The first circuit would stay on always and the second would flash, not fade. The attached circuit should come on gradually (1/4 second) when the switch is pressed and then fade when it's released.
mneary is offline
Old 14th June 2007, 10:37 PM   (permalink)
I think a cigarette prop which would respond to pressure/vacuum similar to a real one would be a pretty cool stage effect. I'm sure one of those tiny 8-pin PICs would do the trick. Or, simply condition the signal from the pressure sensor with some analog circuitry and drive the LED directly.
Jeff
jbeng is offline
Flashing a LED with Mouse Gayan Soyza Electronic Projects 14 23rd December 2008 11:49 AM
36 LED Sequencer HELP NEEDED aquaviventi General Electronics Chat 6 20th August 2007 02:28 AM
Request for help on an LED bar graph circuit by an electronics noob. ThrowingChicken Electronic Projects Design/Ideas/Reviews 38 14th April 2007 02:09 AM
Accessing EEPROM Clayton Micro Controllers 15 23rd March 2007 04:00 AM
Pspice LED Error kogula14 Electronic Projects Design/Ideas/Reviews 3 14th March 2007 05:03 AM
