| Hi I repair clocks and watches to enable me to listen to the tick tock sound the clock or watch makes I use an amplifier made by L&R T300, the unit is very small and is powered by a 9v battery, you attach a sound pickup lead using dbl sided tape (I think it is a quartz pick?) as close as possible to the area of the clock\watch that is making the tick sound, this then allows me to set the clock\watch in beat. My problem is the above unit producing a very loud feed back sound and a low volume tick sound. The electronic circuit is based around the LM386n-1 IC with an amp gain of 200 the power switch automatically turns off after 60 seconds. Can any one suggest a solution other than bin it, that being the case I would like to build a circuit that would allow me to use a crocodile type clip as the sound detector, instead of the dbl sided tape method. Can you recommend a circuit with diagram. Thank you for any assistance that you are able to offer. | |
| Acoustic feedback is caused when the microphone can hear the speaker. Turn down the volume. Separate the mic and the speaker. Enclose the mic so it can't hear the speaker. Wear closed headphones instead of using a speaker.
| Hello Thank you for response. I have just disconnected the 8 Ohm speaker and connected a mono headphone set, unfortunately the continues humming sound is still there and the sound level is controled by the volume slider. The lead to the pickup is 1/2 meter long, half the pick up head is encapsulated. The unit was working ok and then suddenly produced the continues humming sound? Regards Roger | |
| Humming is not acoustic feedback. Humming is caused when the shield on the microphone cable is broken or disconnected and the very sensitive amplifier picks up hum from the surrounding AC mains.
| The shield on the microphone cable is broken adjecent to the pickup, am I correct in thinking that this is a Quatz pick up as the pickup head has a very thin wire coil with a very small metal center encapsulated between two pieces of plastic. When the piece of metal in the pick up was taped the sound was produced by the amplifier. Roger in Essex in the UK | |
| The hum will disappear if you fix or replace the damaged shielded cable.
| Problem with LCD code? | spondootre | Micro Controllers | 15 | 29th April 2008 10:15 AM |
| Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) | smilen | Micro Controllers | 15 | 21st November 2005 10:23 AM |
| counter clock | 111 | General Electronics Chat | 7 | 3rd July 2005 01:51 AM |
| Help me on basketball's game clock and shot clock! | syaw_007 | Electronic Projects Design/Ideas/Reviews | 1 | 6th September 2004 10:50 PM |
| Ask for the principle of error amplifier in PWM | swear_swear | Electronic Projects Design/Ideas/Reviews | 2 | 29th July 2003 02:07 AM |
