Old 17th June 2007, 04:13 PM   (permalink)
IR2111 is an Half Bridge driver not H-Bridge.
That kind of IC used for half-bridge power design (switching power supply), the others are, full-bridge, fly back, and forward converter.
Please look at the level shift stage (datasheet block diag), they need more higher voltage to operate normally. The bootstrap diode and caps isn't functional, if the low side mosfet not been activated (the caps charged through diode when output is low and will float higher to supply the high side mosfet Vgs when output is high).
For H-Bridge, you need more higher voltage to drive N-MOSFET (to supply the Vgs). But you may used P-MOSFET (IRF9540) for the high side driver without more voltage needed.
Gate resistor (ordinary 10-15ohm) used to prevent gate oscillation.
Blatman Bond is offline   Reply With Quote
Old 17th June 2007, 04:44 PM   (permalink)
You might consider a chip like the Intersil HIP4081, which has an oscillator for producing the voltage for the top MOSFET, and allows you to do 100% duty-cycle on the top MOSFET.
NewBie/Jarhead is offline   Reply With Quote
Old 17th June 2007, 08:12 PM   (permalink)
What are you using this h-bridge for?
If it's for PWM a bootstrap capacitor can be used to drive the high side MOSFETs.
If it's for DC then you need a higher voltage to drive the high side MOSFETs.
You can build a voltage doubler from a 555 timer to drive the high side MOSFETs from.
Screen name: Aloone_Jonez
Old 17th June 2007, 08:35 PM   (permalink)
i m using it to drive a 12v dc turbine from a 5 volts logical circuit...
i took a look on the HIP4081(http://pdf1.alldatasheet.com/datashe...datasheet.pdf)... it looks so easy to use and suitable to the case i have....i want to know something about it... i connect the mosfets directly to the ic outputs ?? without resistors ?
is it fully working with irf540 mosfets and 12v battery ??
Inferno is offline   Reply With Quote
Mosfet Driver ! Inferno Electronic Projects Design/Ideas/Reviews 0 13th June 2007 04:22 PM
Simple High side N-Channel MOSFET driver clipo General Electronics Chat 10 5th April 2007 03:43 PM
Mosfet Driver Chip 2camjohn General Electronics Chat 10 9th January 2005 03:35 PM
Here is a list of semiconductor prefixes. TPS Datasheet/Parts Requests 0 21st December 2003 07:24 PM
Identify Semiconductors by prefixes mixos Datasheet/Parts Requests 0 10th December 2003 06:55 PM
