Old 12th June 2007, 12:12 PM   (permalink)
Default Help! Frequency to voltage conversion!
I'm building a tacho for a race car, and I was originally going to use an LM2917 f-v converter and a LM3914 LED bar chart chip.
Thing is, the way I was going to supply the LM2917 with a frequency was through the ECU, which would output a logic level square wave of varying frequency.
I read on these boards that the LM2917 needs a AC input, and won't work off a pulsed DC signal. Any way round this?
Cheers all!
funkychicken9000 is offline
Old 12th June 2007, 12:35 PM   (permalink)
Pulsed DC is AC - it will work perfectly!.
Old 12th June 2007, 12:38 PM   (permalink)
Are you sure? In this thread audioguru says it won't...
To clarify, I'm using the 8-pin version - will connecting the pulsed DC straight into pin 1 work?
Old 12th June 2007, 12:54 PM   (permalink)
You simply feed it through a capacitor, and a resistor to chassis (0V), it will then be centered around 0V. AC doesn't have to centered around 0V either, it depends entirely where it comes from!.
There is essentially no difference between AC and pulsed DC.
Old 12th June 2007, 02:00 PM   (permalink)
I agree. Capacitor-coupling into a resistor to ground will be OK to feed DC pulses into an 8-pins LM2907/LM2917.
audioguru is online now
Old 12th June 2007, 02:53 PM   (permalink)
Cool. Any tips on R and C values?
Old 12th June 2007, 03:12 PM   (permalink)
The datasheet has formulas and examples.
Old 21st June 2007, 05:02 PM   (permalink)
I was wondering about the values I'd need for the resistor and capacitor to connect my pulsed dc input waveform to the LM2917.
Am I right in thinking I connect the signal through a capacitor and resistor in series to ground, and connect the LM2917 input to the joint between the capacitor and resistor? If so, what sort of size resistor and capacitor would I use? I'm assuming I'd want the RC time constant to be large relative to the period of oscillation of the input, but since this is going to vary between around 1kHz and 60kHz, I'm not sure exactly what to choose - would say 10k and 100nF be ok?
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
voltage to frequency converter neelam29 General Electronics Chat 2 4th September 2006 02:25 PM
Help with LM2917 Frequency to Voltage Converter crice Electronic Projects Design/Ideas/Reviews 10 14th August 2006 08:31 PM
Frequency to Voltage jesusfreak General Electronics Chat 17 19th March 2004 08:29 AM
frequency to voltage converter Mojalco Electronic Projects Design/Ideas/Reviews 1 12th November 2003 03:45 AM
