Old 10th June 2007, 05:59 PM   (permalink)
Default Why this simple oscillator/flasher doesn't work?
I'm trying to understand why this simple led flasher doesn't work. The concept is that the capacitor will charge enough (.6v) to turn on the transistor. The transistor will use up (discharge) the capacitor by switching collector/emitter turning the led on. The transistor will then switch off as the capacitor charges again.
On the breadboard with a small capacitor the led flashes once and turns off. I guess this is because the capacitor is fully charged and won't allow the DC current to pass through it anymore?
With a large capacitor the LED stays on all the time. I'm guessing this is because the capacitor is not fully charged so it allows the DC current to pass through?
Sorry I'm new to this and I'm trying to understand the concepts so I can hopefully design my own circuits later on.
RussellH is offline
Old 10th June 2007, 06:11 PM   (permalink)
hi Russell,
As you say the capacitor charges up and stays charged up.
A larger capacitor just takes longer to charge up.
You need a second transistor in a circuit that discharges the cap so it keeps repeating the flash
Have a look at this astable circuit.
http://www.play-hookey.com/digital/e...l_astable.html
Example:
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 10th June 2007, 06:28 PM   (permalink)
Hi Eric,
Thanks for the link. I actually have a book that shows a 2 transistor LED flasher but being the minimalist I am I was wonder why I couldn't discharge the capacitor using a single transistor Perhaps by using a feedback of some sort. After all the transistor is a switch so when it turns on I should be able to get an LED or something to discharge the capacitor no?
Here's one (bottom of the page called cheapo oscillator) but I don't quite understand what "NC" means and how this works.
http://members.shaw.ca/roma/twenty-three.html
RussellH is offline
Old 10th June 2007, 06:33 PM   (permalink)
Or build a reverse bias oscillator.
http://www.geocities.com/capecanaver...t2.html#SINGLE
Screen name: Aloone_Jonez
Hero999 is offline
Old 11th June 2007, 12:47 AM   (permalink)
Thanks. What exactly is different about reverse-bias that makes the same transistor function differently?
Where can I find more info. Anyone have a source that breaks down circuit at the component level to tell you how and why the circuit does what it does. I look at circuits and I go...how did they ever figure that out?
RussellH is offline
Old 11th June 2007, 09:43 AM   (permalink)
It's simply using the reversed biased BE junction as a zener diode, they usually zener about 7V or so?.
Nigel Goodwin is online now
Old 11th June 2007, 10:53 PM   (permalink)
It's not zener breakdown but avalanche breakdown.
The voltage on the capacitor builds up until the transistor suddenly conducts causing it to discharge through the LED until the current is so small it turns off after which is charges again; this cycle repeats over and over.
Hero999 is offline
Old 12th June 2007, 12:26 PM   (permalink)
Depends what you want to call it I suppose?, but you can use the BE junction as a zener diode, about 7V or so - it's a fairly common application.
Old 12th June 2007, 03:27 PM   (permalink)
It looks similar to a white noise circuit I've seen somewhere.
Bill
Smart Kits build Smart People
Old 12th June 2007, 03:40 PM   (permalink)
hi hero,
You are correct its a Vceo, avalanche breakdown relaxation oscillator, nothing to do with Vbe zener operation, thats a different effect.
Eric
PIC tutorials:
Old 12th June 2007, 04:15 PM   (permalink)
Originally Posted by ericgibbs
hi hero,
I looked at the circuit wrong!
Old 12th June 2007, 05:00 PM   (permalink)
Hi Nigel,
It happens to us all.
Eric
PIC tutorials:
Old 12th June 2007, 07:46 PM   (permalink)
hi hero,
Notice, though, that collector and emitter are swapped. In an NPN, Vceo is specified with the collector positive with respect to the emitter. I think it's running as an inverted transistor. It's a (little known?) fact that many transistors have beta>1 when run in inverted mode. Using it this way allows you to use a lower supply voltage than if you had to break down the C-B junction (I have built an oscillator this way). In this circuit, base-emitter breakdown is still the mechanism that initiates current flow. Beta is what provides the negative resistance to make the oscillator.
If I'm full of crap, I'm sure someone will let me know.
Ron
Roff is offline
Old 13th June 2007, 03:33 AM   (permalink)
Did you mean emitter follower? Or some other thing else?
Superman returns..
bananasiong is offline
Need help to make simple scoreboard with LEDs rydad Electronic Projects Design/Ideas/Reviews 10 14th April 2008 09:45 AM
little help with my program please - simple count loop kud0s Micro Controllers 5 7th July 2005 10:40 PM
Controlling Simple Transmitters with Crystals Iceman_Chris General Electronics Chat 3 7th May 2005 05:13 AM
Simple IR demodulator hatman Electronic Projects Design/Ideas/Reviews 3 27th February 2005 11:02 AM
a hard project to get to work!! cloudkicker101 General Electronics Chat 2 12th November 2003 02:39 AM
