hi, please I want to know how to calculate the capacity that found between the trans and coll of transistor in the colpitts oscillator
sometimes the oscillator is using like an rf reciever which freq we can take in our calculation greeting |
It's a shame because there was a great site containing this sotr of formula but I don't know if it's still with us.
http://www.electronics-tutorials.com...scillators.htm
the base to emitter cap = 47 pF base bias resistor = 100K assuming 10MHz crystal (use larger R for lower frequency) emitter resistor = 1K (tune for desired collector current) emitter capacitor: use formula R(emitter) x C = 0.5/freq (freq in MHz), C in uF, R in ohms. Typical value is 100 pF for 10Mhz crystal The best values are the ones that maximize the voltage swing across the crystal.
RadioRon |
What about the LC colpitts oscillator?
That's what I thought he was talking about I didn't think that Colpitts is normally used for crystals, I thought Pierce is normally used for crystals.
I believe that colpitts is commonly used with crystals and most of the configurations below 20 MHz don't require inductors. It is an emitter follower configuration. The crystal provides the resonating inductance and the collector circuit need not be tuned as you usually take output from the emitter. However, if you want to pull harmonics from the oscillator, tuning the collector is done, with output taken from the collector. I've also seen harmonic colpitts oscillators that use an inductor from emitter to ground and take output from the emitter.
I have seen confusion in the past with the names of various oscillator configurations. Are we talking about different oscillator configurations?
RadioRon |
RadioRon |
hi, thank your help but for clear what I mean it I send you with this Thread two schematic one of colpitts oscillator and other I design it by my self
my objective by this question is using them like an RF receiver schematics - you can see an capacity in first one between coll and trans of transistor that what I search about in calculation please simple way - second one I do not know about ITs work or not there is capacity between coll and base of T what is your openion about it and ITs value thank you |
I think Yacine wants to make a super-regenerative receiver. Perhaps he should Google that term.
see my website: www.geocities.com/russlk |
| Colpitts variable oscillator | capone | General Electronics Chat | 7 | 27th May 2007 09:34 PM |
| Help!!! Colpitts oscilator!!! | FCE | General Electronics Chat | 2 | 29th November 2002 11:43 PM |
