Old 9th June 2007, 08:59 PM   (permalink)
Default Battery takeover for poor line voltage
Just kind of thinking about something...
Would it be fairly easy to build a circuit that switches between battery power and line power when line voltage anomalies are detected? Like a UPS, but for a 9-volt wall-wart and battery?
Getting more complicated I'm sure, but I was also thinking of putting a 9-volt rechargable battery as the "ups", and have it recharge when not in use and under normal line voltage.
Would the recharging process change the voltage? So once the line comes back to normal and input power is switched back to it, the charging process will throw it back out of whack until it's recharged (creating a catch22).
Here's the background:
I have wireless security cameras around my house and they recently started frequency-drifting sporadically. I *think* I've traced it down to our air conditioners (and the rest of the neighborhoods a/c's) changing the incoming line voltage, causing the camera power to change slightly, resulting in slight frequency shift. They're cheap little cameras, so input power affects frequency. The shift is just enough to cause annoying lines on the screen, which fools the software into thinking it's motion and constantly recording...
Ratch is offline   Reply With Quote
Old 9th June 2007, 09:02 PM   (permalink)
All you generally require is a couple of diodes, and a resistor - it's VERY simple, and 'switches' instantly.
Old 9th June 2007, 09:19 PM   (permalink)
How would the circuit be selective between sources? Through whichever one is higher?
I can see arranging the diodes so as not to feed line voltage to the battery and vice verse, but I can't seem to grasp how to make it selective. Can you elaborate a little?
Old 9th June 2007, 09:30 PM   (permalink)
Here it is, it's nothing complex as Nigel said.
If you're worried about the battery discharging back into the wallwart then add another diode on the input.
If you really want a steady voltage then add a voltage regulator on the output.
Screen name: Aloone_Jonez
Old 9th June 2007, 09:33 PM   (permalink)
edit: Nevermind, just realized my mistake...
What is the resistor for? It seems like the circuit would also work if the resistor was just an open. Does it smooth out the power or something?
Old 9th June 2007, 09:36 PM   (permalink)
What about using Zener's on the line input? So all incoming voltage would simply cease when it drops below the zener value.
Is that practical?
Old 9th June 2007, 09:46 PM   (permalink)
The resistor limits the current into the battery, if it was short circuited the battery would overcharge and explode, it it was open circuit it would never charge.
Is that practical?
Why would you want to do that?
The circuit starts running from the battery when the input falls 0.7V below the battery voltage.
Old 9th June 2007, 10:20 PM   (permalink)
ah, I see. I didn't realize that circuit was including the rechargable battery, I thought the rechargable idea was ignored for the moment.
I figured a 9-volt zener would prevent both sources from being "on" at the same time, but I guess that really doesn't matter.
Old 9th June 2007, 10:41 PM   (permalink)
Hi Ratch,
If you want a more sophisticated solution check this out:
http://www.intersil.com/data/fn/fn3183.pdf
on1aag.
on1aag is online now   Reply With Quote
Old 9th June 2007, 10:44 PM   (permalink)
It's in the wrong place though! - it's better across the bottom diode, that way it doesn't provide a discharge path back through the charger circuit when the power goes off. It may make no difference, as the charger may just be coming from a bridge rectifier? - but it does no harm across the diode, and most likely will be advantageous!. Certainly though, without knowing the exact circuit of the charger, it makes sense to put the resistor across the diode.
Old 9th June 2007, 11:03 PM   (permalink)
I agree.
It seems so obvious I don't know why I didn't think of it.
I've modified the original schematic.
Old 11th June 2007, 04:24 AM   (permalink)
I don’t know what type of battery you use.
Its better you ignore the recharging unit for the time being.
Because battery charging is a different wide subject. Different circuits needs to charge each battery types (chemistries).
Due to unavailability of NICD now widely use NIMH. It needs complicated charging circuits.
If charging required SLA can use for the circuit in its STANDBY VOLTAGE specifications with continuous charge. But SLA battery voltage comes in 6V & 12V series.
If no charging required the simple diode can do the job to shift to the battery backup.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline   Reply With Quote
Old 11th June 2007, 08:52 AM   (permalink)
Not really much different to NiCd? - and this same circuit will work perfectly with either - the resistor is only for trickle charging the battery.
Old 11th June 2007, 09:22 AM   (permalink)
Will see how long he will use his battery even with a trickle charge current through this 50 cent resistor continuousely?
Reducing battery life is a good idea! Otherwise no business for the battery manufactures.
Gayan
My Website
Old 11th June 2007, 10:27 AM   (permalink)
Due to unavailability of NICD now widely use NIMH. It needs complicated charging circuits..
In this application the circuit given is quite adequate, the resistor serves as a charging current limiter for the battery.
NiMH cells are very similar to NICd and are supposedly less prone to 'memory' effect.
I'm wondering if you're thinking of Lithium Ion cells where this would be true- Lion cells do need a more complex charging circuit.
CheapSlider is offline   Reply With Quote
Voltage ElectroMaster Electronic Theory 44 8th August 2007 05:35 PM
Could someone help me? liqi0003 Electronic Projects Design/Ideas/Reviews 28 8th February 2007 04:09 PM
Car Battery Voltage Question Apoch Electronic Projects Design/Ideas/Reviews 4 21st January 2005 05:13 PM
battery voltage for micro and motor banh Micro Controllers 4 29th July 2004 02:53 PM
Battery pack voltage monitor Scarr General Electronics Chat 2 28th July 2004 05:58 AM
