Old 11th June 2007, 11:33 AM   (permalink)
Originally Posted by Gayan Soyza
Will see how long he will use his battery even with a trickle charge current through this 50 cent resistor continuousely?
NiCd and NiMh are designed to be permanently trickle charged - even complex chargers do the same thing, except they fast charge the battery first, then drop to a trickle charge.
Old 11th June 2007, 10:56 PM   (permalink)
If you want to charge the battery in 20 hours then tricle charge is fine but most people don't want to wait that long and this is why battery manufacturers have developed complex fast chargers.
Screen name: Aloone_Jonez
Hero999 is offline
Old 12th June 2007, 06:45 AM   (permalink)
Also be aware that most "9v" rechargeable batteries are actually 7.2v, although some are 8.4v.
mneary is offline
Old 12th June 2007, 01:00 PM   (permalink)
Originally Posted by Ratch
I *think* I've traced it down to our air conditioners (and the rest of the neighborhoods a/c's) changing the incoming line voltage, causing the camera power to change slightly, resulting in slight frequency shift. They're cheap little cameras, so input power affects frequency. The shift is just enough to cause annoying lines on the screen, which fools the software into thinking it's motion and constantly recording...
If this is truly the problem, then the solution is to get a decent power supply that can maintain proper regulation. You don't need a UPS/battery for this.
SDG is offline
Old 17th June 2007, 02:27 PM   (permalink)
True, but this circuit is very handy to keep data CMOS static memory when the power is interrupted.
Hero999 is offline
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
Could someone help me? liqi0003 Electronic Projects Design/Ideas/Reviews 28 8th February 2007 05:10 PM
Car Battery Voltage Question Apoch Electronic Projects Design/Ideas/Reviews 4 21st January 2005 06:13 PM
battery voltage for micro and motor banh Micro Controllers 4 29th July 2004 03:54 PM
Battery pack voltage monitor Scarr General Electronics Chat 2 28th July 2004 06:58 AM
