| I'm trying to make a circuit to do the following: When 2.5V is applied, it start some sort of countdown timer (30-60 min). When that timer is over, it triggers another circuit which opens a circuit for a minute. During that minute, another 2.5V will be applied and the process will start over again. Could someone point me in the right direction? | |
| You could look into a 555 timer IC. You could use a quad (I think it's the 556) for multiple timers to support your multiple time values. There are more components and calculations involved, such as resistors and capacitors to set the timing. You might also be able to use some time-delayed relays to simplify it. | |
| You could also use a PIC to simplfy the circuit even further.
What kind of supporting circuitry does a pic need? If none, then it would simplify a lot of projects I have going, too. | ||
| I don't think a 555 was meant to do 30-60 minute delays... Microcontrollers are great, not sure about PIC, guess it could be made to work And of course you'll need a programmer, learn to program the device, maybe learn to program in general... | |
As suggested, you don't need to use a PIC, they are just the most popular and best supported ones - but ANY micro-controller could easily do it, it's a very trivial application. | ||
__________________ Superman returns.. | ||
| 555 timer countdown | admeech29 | Electronic Projects Design/Ideas/Reviews | 4 | 27th May 2007 02:38 AM |
| Countdown Timer buzzer | Stevie_j_b | Electronic Projects Design/Ideas/Reviews | 8 | 9th March 2007 03:12 PM |
| Countdown timer | clifweb | Electronic Projects Design/Ideas/Reviews | 3 | 29th August 2006 06:30 AM |
| Countdown Timer | ctduong1 | Electronic Projects Design/Ideas/Reviews | 6 | 2nd November 2004 05:50 AM |
| countdown timer code | ah_Hui | Micro Controllers | 0 | 26th April 2004 06:31 PM |
