| I am trying to create a little quiz type game, like the popular show Sale of the Century. Our family would use the device to determine who will be able to answer the question when the TV show asks a question. Specifications: 1) There are 3 players each with a press button and 2 LED's, Green and Red. 2) The first button pressed illuminates it's GREEN LED, and locks out the other 2 players, illuminating their RED LED's. 3) There is to be a RESET press button to turn off all LED's and make the circuit ready for the next question/round. I will use CMOS 4000 series ICs. Main Gate Type - NAND gates Switching - Active high switch LED's - Active high LED's Quad 2 input NAND gates are to be used, CD4011B. Inverter - HEX buffer Inverter TC4069 The power supply will be a 9 volt battery. See the attachment for a diagram. I have 2 Q's. 1) Need some help with resetting the circuit so all the LED's are off before the next round can begin. 2) Is this the right place to stick the inverter? | |
| Your schematic isn't very clear. This is how I would do it anyway. ![]()
I have looked very carefully thru you drawing, I can see what you are trying to do, but you will require a lot more logic to make it do what you want. Its a very good idea, but I would suggest you relook at your design. The problem with latches, is that one half of the latch must be ON and the other half OFF, until you flip it over, then they change to OFF, ON.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 9th June 2007 at 01:44 PM. | ||
| Hi Sambols, If you want the circuit to function the way you described, you gonna have to make a few minor modifications. on1aag. Last edited by on1aag; 9th June 2007 at 02:17 PM. | |
| hi on1aag, That should get the job done, I was thinking along the same lines. I dont like to discourage young 'students' but the way that he had it drawn, it would not have worked without additional logic. The problem he would have run into, was locking out the other players, on any 1st push. Regards
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 9th June 2007 at 02:22 PM. | |
| Can you help me to better understand the lockout using the following diagram. | |
| hi, Hope on1aag dosnt mind too much. Look at the drawing, when the RESET pb is pressed, thats the RED lettering if #1 pb is pressed thats the BLACK lettering. Basically after a RESET, any #1 thru #3 pb will change the state of its input latch and generate a clock pulse for the output latches. After that single clock pulse no more postive going clock pulses can be generated, until the system is RESET.
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:20 PM. | |
| slow response int on RB change | williB | Micro Controllers | 9 | 23rd September 2006 07:39 AM |
| Linear Phase Response ? | Electrix | General Electronics Chat | 11 | 9th November 2005 02:59 PM |
| Infrared detector response time | QuickStrike | General Electronics Chat | 4 | 26th June 2005 04:18 AM |
| sim-op amp-closed loop frequency response in LTSWcad3 | Electricman2K5 | General Electronics Chat | 7 | 3rd May 2005 09:58 PM |
| Modem Response question. | liupengjian | General Electronics Chat | 1 | 18th June 2004 05:43 PM |
