Notices
Old 5th June 2007, 02:58 PM   (permalink (permalink))
Default Need advice on making a DIY car MP3 charger
Hello all, any advice on how one would construct a charger for an MP3 player to be used in an auto? What would I need to convert the car's power supply (13.2v, ?? amps) into a suitable supply for the MP3 player (5v, 2a)? Any help would be greatly appreciated! Thanks, Brian
baristabrian is offline
Old 5th June 2007, 05:39 PM   (permalink (permalink))
Your MP3 player probably has an operating current much less than 2A.
Use an LM317 adjustable voltage regulator set for a 3V output. Its max current is 1.5A. You are throwing away about 10.5V so it will get hot and will need a heatsink.
audioguru is online now
Old 5th June 2007, 07:59 PM   (permalink (permalink))
buy a moto razor cell phone charger off ebay for $1.99 and call it done.
the razor chargers are dirty cheap 'cause the phone is so popular. the charger already contains an efficient switch mode buck converter, and since it's for the razor, it already has the mini-usb connector on it.
if mini usb doesn't work for you, you can lob the end off and solder on whatever end does work.
or yea, you can hack together something using a cold-war era linear regulator like the lm317 or easier still the lm7805. it'll waste more power than it provides.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 5th June 2007, 10:22 PM   (permalink (permalink))
Thanks for the input guys. Sounds like the DIY route may not be that feasible. I noticed the PlayStation Portable charger has a 5v 2a output. I may go that route. Sounds like the "switch mode buck converter", whatever that is, is what I need. And it doesn't sound like something I'm going to get for $1.59 at Radioshack. Thanks again for the advice! Brian
Old 5th June 2007, 11:38 PM   (permalink (permalink))
I bought some switch-mode 5VDC/2A tiny power supplies for a couple of dollars at a surplus electronics store. They are name-brand and were made for a router that is now obsolete. The power supplies are only 2 years old.
Older ones would cost about $60.00 at Radioshack.
Old 6th June 2007, 12:46 AM   (permalink (permalink))
unless your mp3 player is very old, I can't see how it would require 2 amps. 2 amps at 5v is 10 watts - a lot of energy for a battery powered device.
my guess is you're getting the 5v/2a rating from the wall charger or something?
Favorite numbers:
justDIY is offline
Old 6th June 2007, 03:43 AM   (permalink (permalink))
Yeah, it's kinda old....here's the owner's manual with the specs.
http://www.iriveramerica.com/download/H100/H120_Eng.pdf
I recently replaced the stock iRiver battery with a 1st gen. iPod battery (getting 24+ hr. run times!). Would 550 mA keep it topped up? Or does the player have some charging circuit that requires 2A? Guess I could always hack the USB end off my phone charger and see! Thanks again! B
Old 6th June 2007, 12:56 PM   (permalink (permalink))
If the 1st gen. iPod battery has a higher capacity then the stock battery then it will probably take longer than 3 hours to charge from being completely discharged, if the stock 2A charger is used. A 550mA charger would take 4 times longer.
Old 6th June 2007, 12:58 PM   (permalink (permalink))
if it's running for 24 hrs on an ipod battery, take the current rating (mah) for that battery, and divide by 24 - that will tell you how many amps your device needs (roughly)
Favorite numbers:
justDIY is offline
Old 6th June 2007, 02:51 PM   (permalink (permalink))
But your calculation is for the current used by the MP3 player, it does not include charging current for the battery.
Old 6th June 2007, 03:14 PM   (permalink (permalink))
Wow, you guys are good! I'm sort of an electro-neophyte, but after successfully replacing the battery and building a surprisingly good sounding CMoy headphone amp I was all gung-ho construct a home brew charger as well. I'm beginning to realize the eBay PSP charger may be the practical (and safer) way to go. Thank you all for the input! Having such a knowledgeable group as youselves available to help out on any future projects will bolster my confidence greatly. So glad I stumbled across your forum, it's a wonderful asset!
diy laptop battery charger circuit gunsmoker Electronic Projects Design/Ideas/Reviews 2 12th February 2007 06:48 PM
